Hi - with long press you can change the order of the tiles ![]()
You‘re able to use the slider to open and close the blinds/rollers?
No, they have no sliders. In homey you need to long press to open the control, as with any device. Its Somfy RTS
Hey, great Work. Is it possible to start Flows?
Starting Flows is implemented now
Great work - I updated the app and restarted the wall display and: the flows are working.
Amazing work - I really appreciate it
Thank you
For next updates: you do not have to restart the Wall Display.
Just swipe down and there should be e refresh icon. Works as well, when changing settings in the app.
Please install version 1.2.1 and let me know how it looks like now (please send a screenshot of the button in the browser).
version 1.2.1: tap to open/close, stop button, live status
Please update again
1.2.2: Customizable dashboard title (Design tab); stop button for one-way blinds enlarged
Which setting?
Larger stop button, should there be an option for it in the design tab or should it be bigger automatically? Either way, no change
It should be a bit bigger
Kann mir jemand sagen, wie das Ganze eingerichtet wird, dass auf dem Display auch etwas angezeigt wird. In der App habe ich nichts gefunden.
Danke schon mal.
Hallo Peter
Die Anleitung findest du hier: andiwirz/com.walldisplay.dashboard: Homey App for a Homey Dashboard on Shelly Wall Display
oder im ersten Post ganz oben.
LG
Two new options for Flow tiles in Settings → Flows:
Flow Confirmation Dialog
When enabled, a confirmation dialog appears before any flow is started — useful to prevent accidental triggers on a wall display.
Flow Position
Choose whether flow tiles appear above or below the device tiles. Default is above (as before).
v1.2.6 — Energy history chart fix
Bars were exceeding the Y-axis when solar production was above ~50 kWh/day. The chart now scales correctly regardless of how much solar is produced.
v1.2.7 — Drag & drop for flow tiles
Flow tiles can now be reordered by long-pressing and dragging — just like device tiles. The order is saved and restored automatically. Text selection on the dashboard has also been disabled to make dragging smoother.
v1.2.8 — Settings redesign
Energy Dashboard moved to Design tab; active tab highlighted in orange; support link in header
