Homey Dashboard on Shelly Wall Display XL
I got a question in another tread about my image of Homey Dashboard running on the Shelly Wall Display XL. So I thought I try a guide here instead.
I’ve tried to remember the steps. But basically you need to enable developer options on the Shelly, enable ADB and open android settings. You always launch the Homey app from the Android settings.
The most cumbersome part is to get the right APKS for Homey and SAI.
You might need to troubleshoot this, but all-in-all it should work something like this. I could be wrong on some points, but you will probably get the idea.
If something does not work, or does not add up - let me know. I did all this a while ago.
Also, this is non-destructive. So your default/normal Shelly app will always work. You can always just press the Shelly icon to go back like nothing ever happened.
Quick Summary
  1. Enable Developer Options on the Shelly device
  2. Enable ADB (Wi‑Fi or USB)
  3. Transfer SAI APK and Homey APK/APKS files to the device using ADB
  4. Install Split APKs Installer (SAI)
  5. Install Homey using SAI (all split APKs together)
  6. Launch Homey via Settings → Apps → Homey → Open
Prerequisites
  • Shelly Wall Display XL powered on
  • Android 11
  • Network access (Wi‑Fi)
  • Homey app provided as:
    • a single .apks file, or
    • multiple APK files (base APK + configuration APKs)
      (Make sure it contains config.armeabi_v7a.apk)
  • Split APKs Installer (SAI) APK
  • Computer with Android Platform Tools (ADB)
Step 1 – Enable Developer Options
  1. Open Settings on the Shelly device
  2. Go to About Device
  3. Tap the following items in this exact order:
    FW Version
    Hardware revision
    FW Version
    FW Version
    Hardware revision
    FW Version
    Hardware revision
    Hardware revision
  4. A message will appear confirming that Developer Options are enabled
Step 2 – Enable ADB
  1. Go to Settings → Developer Options
  2. Enable:
    • ADB
    • ADB over Wi‑Fi (recommended)
  3. Note the device’s IP address
    (found under Settings → Network / Wi‑Fi)
Step 3 – Connect to the Device Using ADB
ADB over Wi‑Fi
On your computer:
adb connect <DEVICE_IP>:5555
Example:
adb connect 192.168.1.123:5555
Accept the authorization prompt on the Shelly display.
Verify connection:
adb devices
ADB via USB (Alternative)
  1. Connect the Shelly device to your computer using a USB cable
  2. Enable USB debugging when prompted
  3. Verify connection:
adb devices
EASY STEP
If this works for you, then use this. Otherwise, continue to step 4.
Make sure you are in the folder on your MAC/PC where the three apk files are:
adb devices
adb connect "YOUR-IP:PORT"
adb install-multiple Homey-9.6.5.apk config.armeabi_v7a.apk config.xxhdpi.apk
Then continue to Step 7
Step 4 – Transfer Installation Files to the Device (ADB)
All installation files are transferred to the Shelly device using ADB.
Create a Working Folder on the Device
adb shell mkdir -p /sdcard/Download/install
Transfer Split APKs Installer (SAI)
From the folder containing SAI.apk on your computer:
adb push SAI.apk /sdcard/Download/install/
Transfer Homey Files
If you have a .apks file:
adb push Homey.apks /sdcard/Download/install/
If you have multiple split APK files:
adb push Homey-<version>.apk /sdcard/Download/install/
adb push config.armeabi_v7a.apk /sdcard/Download/install/
adb push config.xxhdpi.apk /sdcard/Download/install/
All files should now be available under:
Downloads → install
Step 5 – Install Split APKs Installer (SAI)
SAI is installed by opening the transferred SAI.apk file directly on the Shelly device.
  1. On the Shelly device, open Settings → Apps
  2. Open the File Explorer (where you can see downloaded files) and navigate to:
    Downloads → install
  3. Tap SAI.apk to start the installer
  4. If prompted, allow installation from unknown sources:
    • When Android shows “Install unknown apps” for the app you used to open the file (often a file manager / downloads app), enable Allow from this source
    • Go back one step and tap SAI.apk again
  5. Complete the installation
Step 6 – Install Homey Using SAI
  1. Open Settings → Apps → Split APKs Installer
  2. Tap Open
  3. In SAI, tap Install APKs
  4. Navigate to:
    Downloads → install
Installation Options
  • Select the .apks file
    OR
  • Select all Homey APK files at the same time (base + config APKs)
  1. Confirm installation
  2. Wait for Installation successful
:warning: Installing only the base APK will cause the app to crash.
Step 7 – Grant App Permissions
  1. Open Settings → Apps → Homey
  2. Open Permissions
  3. Grant required permissions as needed
Step 8 – Launch Homey
Apps on the Shelly Wall Display XL are launched via Android Settings.
  1. Open Settings
  2. Go to Apps
  3. Select Homey
  4. Tap Open
Troubleshooting
App crashes on launch
  • Ensure all split APKs were installed together
  • Verify correct ABI (armeabi_v7a)
  • Reinstall using SAI
Files not visible in SAI
  • Confirm files were pushed to /sdcard/Download/install
  • Reboot the device if needed
ADB connection issues
  • Ensure ADB is enabled
  • Confirm correct IP address
  • Accept authorization prompt on the device
  • If you’re using ADB over USB, check that the cable you are using is actually for data (don’t ask me how I know)
Thanks for your great explanation.
How fast is the Homey app?
Would this also work for the smaller Shelly models?
To be honest, it struggles sometimes. Always when loading the first time.
But once it’s up and running on the dashboard it runs smoothly. So I would not guarantee “better” performance" on smaller models.
But work in practice? Yes.
There is also a way where you can do this through the browser (Android settings → Apps → Browser). You just have to give the permissions. Then you have access to whatever page you need to go to.
Super clear explanation — much appreciated :+1:
I’m still running into an issue on Shelly firmware 2.5.5, where I can’t seem to get it to start properly.
Which Homey app version are you using on your side? That might help me pinpoint where the difference is.
I just checked. I’m running Homey 9.6.5 on the Shelly.
Shelly is running 2.5.5 (latest)
From what I can remember I tried with different versions until I got it right. And I believe I even tried different “downloads” of the 9.6.5 version as well.
I tried going back in my terminal to see the commands I tried afterwards while trying to update and found this (so that might even work without the SAI)
So basically,
  1. adb devices
  2. adb connect "YOUR-IP:PORT"
  3. adb install-multiple Homey-9.6.5.apk config.armeabi_v7a.apk config.xxhdpi.apk
    (you have to do this from the folder where you have the files)
See if that works!
Thanks for the quick reply. Any suggestions where I can download your version? I tried APKpure but i got a config.arm64_v8a.apk and not the config.armeabi_v7a.apk. I think there is the difference
If you Google “Homey-9.6.5.apk” there should be a site called Apk.watch. Try that :slight_smile:
It might even work with later versions if you have the correct armeabi file.. Really don’t know, but worth a try!
Found if! And that was the issue. So if anyone tries it make sure you have the file with onfig.armeabi_v7a.apk in it
I updated the guide with “easy steps”. Thanks for testing my memory :wink:
Thanks for sharing!
Fantastic write up just what I was looking for thank you!
Question: what does it look like to control Homey functionality, through the Shelly dashboard?
is that not possible or?
I understand I am asking a very elemental question
i had a lot of trouble in till i did it this way it works brilliantly thank you
hello i have noticed that having the app open stops the screen sensors so turn the display off and on when you walk past it can you help with that please
thank you
hi all
i have sorted the buttons out using ( key mapper ) for the back home and volume for the top buuton being you can us singel duble and long press
and i used ( macrodroid and key mapper ) for the bottom one so i have them controlling flows in homey
and turning on the screensaver of the wall display
macrodroid will not let me edit my macros it keeps on crashing but everything elles works fine
Doubting to try this, but heart from sales representatives from Shelly that an official Homey integration is in the Beta testing phase. Any news on that @Doekse?
How? Tried to do it with keymapper, turn off screen with one of the 4 buttons but it does not do anything. And says i need expert mode?
Who designed this thing?
Works in a standard one slot back box but they chose landscape?
Oh dear
Thanks to the clear instructions I can confirm that the described procedure works with the Shelly Wall Display X2i; firmware 2.5.8 and the Homey 9.6.7 apk files. I used the ‘fast path’ which is pretty straight forward.
The Homey app appears to run a bit slow; but my main issue right now is that I am quite new to Android and have no clue how to automatically start it without the need to go to “Developer Options” → “Open Android Settings” → “Apps and notifications” → “Show all 15 apps” → start Homey,
Aside from that, the app only shows in portrait mode, but it is my intention to install the display in landscape mode over 2 existing wall sockets.
Any suggestions are appreciated!
Thanks again,
Tom
Hi
the new beta firmware 2.6.0 for the Shelly XL Wall Display now includes an integrated app store, where, in addition to the Home Assistant app, the Homey app is now also available. Overall, the app works well, although it feels a bit sluggish at times.
If it feels sluggish now, what’s the point?
It will only get more annoying as time goes on and more functionality gets added.
I never understand the business decision to put an underpowered CPU in these massive displays
Just put a solid CPU and 8GB of ram for an extra £100 and everyone will still buy one.
Android 11 smh ! ! !
