After the update (8.0.0) I have the same - TV not found. Check IP address.
@balmli added a new PR. Seems that it broke the init of the devices
After the update I don’t get the message anymore. But the tv won’t respond.
My power state poling is off and after update to 8.0.0 the off and on works correct from my flows. Before it had an explanation mark and nothing works.
OK, thanks. I will have a look at it.
With the new update everything works great again. Thank you!
Thanks for reporting back !
My list of inputs is empty. Smarthings API is activated
Hi @balmli
I have issues finding my apps but a lot of others I dont have when using the card “Launch app”. I assume I only see the stardard list because the fetching have failed.
I have just send a diagnostic report from the app. (323e9ee9-9a61-4274-b083-2255b2985f6e)
can you help?
Is the tv and homey in the same vlan?
yes, i add the IP-adres of the tv in the setting of the homey app
v. 1.9.0 updated for SDK3 (and Homey Pro Early 2023):
Please test ![]()
Just installed it. For now it is still working.
Yes, please test v. 1.9.2
and report back here if that works ok ![]()
The triangle is gone and I can see if the TV is on and off. But I cannot control anything from the app
Can you:
- first try to control the TV with the app
- then create a diagnostics report (Settings → App → Samsung SmartTv → Settings → Create diagnostics report)
and I might see what’s wrong.
I’m not able to test this myself, since I don’t have such a Samsung - model.
I will create this report later today
Hi
I am trying to use input source.
List is empty
{"device":{"FrameTVSupport":"false","GamePadSupport":"true","ImeSyncedSupport":"true","Language":"en_GB","OS":"Tizen","PowerState":"on","TokenAuthSupport":"true","VoiceSupport":"true","WallScreenRatio":"-1","WallService":"false","countryCode":"NL","description":"Samsung DTV RCR","developerIP":"0.0.0.0","developerMode":"0","duid":"uuid:2de904db-ba66-4c01-9048-3e97da12b880","firmwareVersion":"Unknown","id":"uuid:2de904db-ba66-4c01-9048-3e97da12b880","ip":"192.168.1.157","model":"22_PONTUSM_QTV","modelName":"QE55Q74BATXXN","name":"Samsung Q74BA 55 TV","networkType":"wireless","resolution":"3840x2160","smartHubAgreement":"true","ssid":"9c:c9:eb:e7:15:06","type":"Samsung SmartTV","udn":"uuid:2de904db-ba66-4c01-9048-3e97da12b880","wifiMac":"70:09:71:9E:CB:CA"},"id":"uuid:2de904db-ba66-4c01-9048-3e97da12b880","isSupport":"{\"DMP_DRM_PLAYREADY\":\"false\",\"DMP_DRM_WIDEVINE\":\"false\",\"DMP_available\":\"true\",\"EDEN_available\":\"true\",\"FrameTVSupport\":\"false\",\"ImeSyncedSupport\":\"true\",\"TokenAuthSupport\":\"true\",\"remote_available\":\"true\",\"remote_fourDirections\":\"true\",\"remote_touchPad\":\"true\",\"remote_voiceControl\":\"true\"}\n","name":"Samsung Q74BA 55 TV","remote":"1.0","type":"Samsung SmartTV","uri":"http://192.168.1.157:8001/api/v2/","version":"2.0.25"}
I have the token set and enabled
What should i do?
Hi.
I have a Samsung Q80 witch often need to empty memory/reset the tv, I think this is because of memory get’s full… Is it possible to create a function to do this “reset”/empty memory on the tv from the Homey app? ![]()
