[APP][Pro] Powerview- Luxaflex & Hunter Douglas
[APP][Pro] Powerview- Luxaflex & Hunter Douglas (click reply on the first post)Hi I can make flows with IF and THEN but not AND. I also am not able to fill in the exact percentage when I use IF. I would like to create flows like:
IF duette kitchen is open 75% AND it is 18.00 THEN close it to 50%
Or IF the door is open AND duette bedroom is 100% THEN turn off the ligths
Is it possible to add this to the app or is there a detour?
Thanks
@Hanneke_Rompa currently that’s not possible. You could use homey logic to achieve that. As this app uses default homey capabilities it’s not possible to add that
The duette position isn’t a trigger, it’s a condition;
This flow should be triggered by time:
When..
it is 18.00
And..
logic card [number] is greater than 0.74
(as number you can select the corresponding tag of the duette position)
Then..
set position to 50%
Visual:
This shows how to select such a tag in a logic card:
The resulting flow:
I think it’s very confusing we’re supposed to use 0 - 1 values for 0 - 100% values in most flow cards.
Knowledge base article about Homey logic
https://support.homey.app/hc/en-us/articles/4410240765586-Using-Homey-Logic-in-Flows
Thanks Peter, it helped me a lot.
I changed from using Google for my home network/wifi to NETGEAR. I reused the ssid and password per netgear’s instructions so devices wouldn’t need to be reconfigured. This worked for most devices, but not the Powerview shades.
I have them working from the Powerview app, but not Homey.
I deleted the shades, gateway, flow cards and app from Homey and started again.
Homey sees the gateway and shades, but doesn’t respond to commands.
Please advise.
Did the IP address change maybe? Often, you can set it in the device settings or by using the “Repair” option in Homey
@Carl_Novit update the IP in the settings of the hub inside homey
