The sensor isn’t respording immediately when the lux value changed that is the issue, I need to wait 5 minutes before there is an new value and i want tot refresh the value more often.
My SML004 firmware is 2.53.6 and the app Philips Hue, without the bridge, is on v2.0.51 and updates every second when the light intensity changes.
The value for “Min interval for lux” and “Max interval for lux” is 1 and 60.
Here is everyting the same
Correction, I have 2.0.51 experimental, but that will be the same as the 2.0.51 regular release.
No idea why your sensor does not detect lux changes faster.
I’ve the same problem like @Gertjan_Schuttert. The difference is that I’m using the old SML002 sensor with firmware version 6.1.1.27575. According this page, it’s the latest firmware.
Yesterday I tried several times to change the lux interval with no success. The interval is still at 5 minutes.
But maybe there is a difference in how the sensors were added in Homey. Because the outdoor sensor can be added as an “Outdoor Sensor” or as an “Outdoor Occupancy Sensor”. Mine is added as an “Outdoor Sensor”. And yours @Gertjan_Schuttert and @Rmb?
I have tried to added the senor as “Outdoor Sensor” and as “Outdoor Occupancy Sensor” but I still have the same problem
Mine is connected as an Outdoor Occupancy Sensor, I could not get it connected as an Outdoor Motion Sensor. That was about a year ago.
Hm, unfortunately no clear result. I’m a bit shy about deleting the sensor and adding it as an “Occupancy Sensor” because I use the lux measurement in many flows.
Maybe one day when I have a bit more time.
@Gertjan_Schuttert, if you changed the interval in the advanced device settings, did you wake up the sensor first (with the button on the back) before pressing save?
no i din’t try it in that way, will that works?
All Zigbee and Z-Wave battery-operated devices must be woken up so that changed device settings can be submitted to the devices. With some devices, you have to keep pressing the button after waking up to keep the device awake. However, this differs from device to device and you have to test it yourself.
I now see that my sensor is slow too
, as switching on the light on and off manually introduced a motion alarm, and then the lux is sent too.
My driver is homey:app:com.philips.hue.zigbee:SML002-occupancy
I have try this as well but it won’t work
Hi Dirk,
I’m using also a SML002, also added as outdoor sensor, but with firmware 6.1.0.25261.
I get lux updates every minute as entered in the settings.
Hm, strange.
Did you migrate the sensor from HP19 to HP23 (you have that, don’t you?)? Or did you add the sensor new to HP23?
That’s why we are here. ![]()
No, I started from scratch with HP23 one year ago, but I think I re-installed the SML002 6-9 month ago.
Here the details of the device:
Lux settings:
and 3 sequential lux values:
New Test Version of Philips Hue Zigbee without the Bridge - Updated Zigbee Driver!
Hey everyone,
I’ve just published a new Test version of my app “Philips Hue, without the Bridge”.
This update includes a significant improvement: an updated Zigbee driver that should enhance overall performance and stability.
I would really appreciate it if as many of you as possible could test this version and provide feedback. Your input is invaluable in helping me ensure the driver is stable before I roll out these updates to the Live version. Once this is done, I plan to start adding support for new devices.
You can find the Test version here. Thanks in advance for your support and testing! Let’s make this app even better together.
Cheers!
A thousand installs of the test version and counting, with no crashes or error logs so far… looking good!
If you experience any issues with the test version of the app (but not with the live version), please let me know ASAP.
So far no issues observed…actually seems to be …MUCH faster, is that placebo ?
OK, going Live! ![]()
