It’s correct behavior. See this post Hue Motion Sensor --> Motion or Occupancy? - #4 by johan_bendz
Hi, I have an issue with 2 of the 4 hue remotes (version 2). When I reset them (using the button on the back) and then pair them to my Homey, they will work but after some time (30 min) they will lose connection and a red light blinks when I press a button. It wil not reconnect. Does anyone know a fix to this problem?
Thanks in advance!
Hi @MiniKoelkast, can you please try a few things:
restart the app or homey
use the devices a few times and then wait for them to stop working, when they do… try using them a few times more
send a diagnostic report from the app
remove the non working units from Homey
disable the app (do not remove it, just disable it)
pair the units as generic Zigbee
check if they still are loosing the connection after a while
Please report back to me and label the diagnostic report with your nick / name.
A question to the maker, i bought a year back a Hue Being lamp. Added to homey and works fine with your app.
A few weeks back i bought a new for a other room, but i think this is the one with bluetooth, and is a different 1 than the one iv’e got already working.
Anyway i got problems with adding this to homey, i’m keep getting the device added as a unknown zigbee device.
The product id i’m seeing is 929003055201. Can you help and if this is a new product can you add it to the next update of the app? If you need anything let me know! Thanks.
If a device is added as an unknown Zigbee device, it’s not supported.
If you want to request support for it, please read the first post carefully.
Aah yeah i missed that, i will do that!
EDIT:
"ids": {
"modelId": "929003055201",
"manufacturerName": "Philips"
"endpoints": {
"endpointDescriptors": [
"endpointId": 11,
"applicationProfileId": 260,
"applicationDeviceId": 268,
"_reserved1": 1,
"inputClusters": [
0,
3,
4,
5,
6,
8,
4096,
64515,
768
"outputClusters": [
25
"endpointId": 242,
"applicationProfileId": 41440,
"applicationDeviceId": 97,
"_reserved1": 0,
"inputClusters": [],
"outputClusters": [
33
"endpoints": {
"11": {
"clusters": {
"basic": {
"attributes": [
"id": 0,
"name": "zclVersion",
"value": 2
"id": 1,
"name": "appVersion",
"value": 2
"id": 2,
"name": "stackVersion",
"value": 1
"id": 3,
"name": "hwVersion",
"value": 0
"id": 4,
"name": "manufacturerName",
"value": "Philips"
"id": 5,
"name": "modelId",
"value": "929003055201"
"id": 6,
"name": "dateCode",
"value": "20211210"
"id": 7,
"name": "powerSource",
"value": "mains"
"id": 8,
"name": "appProfileVersion",
"value": 0
"id": 9
"id": 10
"id": 11
"id": 16384,
"name": "swBuildId",
"value": "1.93.7"
"id": 65533,
"name": "clusterRevision",
"value": 1
"commandsReceived": "UNSUP_GENERAL_COMMAND"
"identify": {
"attributes": [
"id": 0
"id": 65533,
"value": 1
"commandsGenerated": "UNSUP_GENERAL_COMMAND",
"groups": {
"attributes": [
"id": 0,
"name": "nameSupport",
"value": {
"type": "Buffer",
"data": [
0
"id": 65533,
"value": 1
"scenes": {
"attributes": [
"id": 0
"id": 1
"id": 2
"id": 3
"id": 4
"id": 65533,
"value": 1
"onOff": {
"attributes": [
"id": 0,
"name": "onOff",
"value": false
"id": 16384
"id": 16385,
"name": "onTime",
"value": 0
"id": 16386,
"name": "offWaitTime",
"value": 0
"id": 16387
"id": 65533,
"value": 1
"levelControl": {
"attributes": [
"id": 0,
"name": "currentLevel",
"value": 254
"id": 1,
"name": "remainingTime",
"value": 0
"id": 15
"id": 16384
"id": 65533,
"value": 1
"touchlink": {
"attributes": [
"id": 65533,
"value": 1,
"reportingConfiguration": {
"status": "UNREPORTABLE_ATTRIBUTE",
"direction": "reported"
"colorControl": {
"attributes": [
"id": 2
"id": 3,
"name": "currentX",
"value": 22267
"id": 4,
"name": "currentY",
"value": 23033
"id": 7,
"name": "colorTemperatureMireds",
"value": 192
"id": 8,
"name": "colorMode",
"value": "colorTemperatureMireds"
"id": 15
"id": 16
"id": 17
"id": 18
"id": 19
"id": 21
"id": 22
"id": 23
"id": 25
"id": 26
"id": 27
"id": 48
"id": 49
"id": 50
"id": 51
"id": 52
"id": 54
"bindings": {
"ota": {
"attributes": [],
"242": {
"clusters": {},
"bindings": {}
I have new lamps : Philips Hue Ambience1100 lumen (806 lumen @ 2700K)
Model Number on Bulb : 9290024684
Sourced @ : CoolBlue
They are also not recognized by the app.
Tried to add them as “Bulb E27 White Ambience BT”
Connect Message after pairing = “Could not find a Homey APP for this device, it has been added as Basic Zigbee Device.”
The Basic Zigbee Device does seem to have all the functionality working though (On/Off, Dimming, Temperature control)
The interview results :
"ids": {
"modelId": "LTA009",
"manufacturerName": "Signify Netherlands B.V."
"endpoints": {
"endpointId": 11,
"_reserved1": 1,
"inputClusters": [
0,
3,
4,
5,
6,
8,
4096,
64514,
768
"outputClusters": [
25
"endpointId": 242,
"_reserved1": 0,
"outputClusters": [
33
"endpoints": {
"11": {
"clusters": {
"basic": {
"attributes": [
"id": 0,
"value": 2
"id": 1,
"value": 2
"id": 2,
"value": 1
"id": 3,
"value": 1
"id": 4,
"value": "Signify Netherlands B.V."
"id": 5,
"name": "modelId",
"value": "LTA009"
"id": 6,
"name": "dateCode",
"value": "20201117"
"id": 7,
"value": "mains"
"id": 8,
"value": 0
"id": 9
"id": 10
"id": 11
"id": 16384,
"value": "1.76.11"
"id": 65533,
"value": 1
"identify": {
"attributes": [
"id": 0
"id": 65533,
"value": 1
"groups": {
"attributes": [
"id": 0,
"value": {
"type": "Buffer",
"data": [
0
"id": 65533,
"value": 1
"scenes": {
"attributes": [
"id": 0
"id": 1
"id": 2
"id": 3
"id": 4
"id": 65533,
"value": 1
"onOff": {
"attributes": [
"id": 0,
"name": "onOff",
"value": true
"id": 16384
"id": 16385,
"name": "onTime",
"value": 0
"id": 16386,
"value": 0
"id": 16387
"id": 65533,
"value": 1
"levelControl": {
"attributes": [
"id": 0,
"value": 254
"id": 1,
"value": 0
"id": 15
"id": 16384
"id": 65533,
"value": 1
"touchlink": {
"attributes": [
"id": 65533,
"value": 1,
"colorControl": {
"attributes": [
"id": 2
"id": 3,
"name": "currentX",
"value": 29973
"id": 4,
"name": "currentY",
"value": 26871
"id": 7,
"value": 366
"id": 8,
"id": 15
"id": 16
"id": 17
"id": 18
"id": 19
"id": 21
"id": 22
"id": 23
"id": 25
"id": 26
"id": 27
"id": 48
"id": 49
"id": 50
"id": 51
"id": 52
"id": 54
"bindings": {
"ota": {
"attributes": [],
"242": {
"clusters": {},
"bindings": {}
It seems that there haven’t been any development on this for quite som time.
Is it possible to add the new devices in the HUE range and get the TAP to work?
Hi! Bought a Philips Hue Outdoor Sensor, which I’m not able to connect. It’ll connect as “Unknown Zigbee Device”.
Saw some posts on Github issues, this may already be a known issue?
I found this @ github, Mik
Quote:
Johan made a test version:
I tested this version for the Hue Indoor sensor. The sensor is recognized but the app makes a occupancy sensor of it, but I selected a Motion sensor.
The occupancy sensor works a bit different than a motion sensor but now you can use the sensor.
Does this work?
Thanks, test version works, but like above the sensor is now a occupancy sensor, but for now it seems to work.
The Occupancy behavior is the correct one for this device, the Motion behavior was used before based on legacy drivers. It does not matter what driver you choose when you install the unit, the correct driver (in this case the Occupancy sensor) will always be used. Only time you have a need to choose a driver is when different apps support the same unit, then the driver you choose will be used.
Is it possible to adjust the motion detection sensitivity? I can edit these for lux and temperature but not for motion…?
Not for now, working on it.
I got two new Hue smart plugs today and both are not recognized by the app.
"ids": {
"modelId": "LOM007",
"endpoints": {
"endpointId": 11,
"applicationDeviceId": 266,
"_reserved1": 1,
"inputClusters": [
0,
3,
4,
5,
6,
8,
4096,
64514
"outputClusters": [
25
"endpointId": 242,
"_reserved1": 0,
"outputClusters": [
33
"endpoints": {
"11": {
"clusters": {
"basic": {
"attributes": [
"id": 0,
"value": 2
"id": 1,
"value": 2
"id": 2,
"value": 1
"id": 3,
"value": 1
"id": 4,
"id": 5,
"name": "modelId",
"value": "LOM007"
"id": 6,
"name": "dateCode",
"value": "20201117"
"id": 7,
"value": "mains"
"id": 8,
"value": 0
"id": 9
"id": 10
"id": 11
"id": 16384,
"value": "1.76.11"
"id": 65533,
"value": 1
"identify": {
"attributes": [
"id": 0
"id": 65533,
"value": 1
"groups": {
"attributes": [
"id": 0,
"value": {
"type": "Buffer",
"data": [
0
"id": 65533,
"value": 1
"scenes": {
"attributes": [
"id": 0
"id": 1
"id": 2
"id": 3
"id": 4
"id": 65533,
"value": 1
"onOff": {
"attributes": [
"id": 0,
"name": "onOff",
"value": false
"id": 16384
"id": 16385,
"name": "onTime",
"value": 0
"id": 16386,
"value": 0
"id": 16387
"id": 65533,
"value": 1
"levelControl": {
"attributes": [
"id": 0,
"value": 254
"id": 1,
"value": 0
"id": 15
"id": 16384
"id": 65533,
"value": 1
"touchlink": {
"attributes": [
"id": 65533,
"value": 1,
"bindings": {
"ota": {
"attributes": [],
"242": {
"clusters": {},
"bindings": {}
any update on when the switch module will be available? Or anyone who can add this one?
Did you update to the latest version of the app?
That seems to work
