Looks like Radio 10 is not working the last couple of days. All other radio stations working fine.
Which url is used for Radio 10. Want to test if that is the cause,
Hi there, really nice app, but I can only get it to work in 1 flow properly… It seems the IF/WHEN “radio station changed” can only be used once… I have multiple buttons and speakers in my house on different floors and I want to be able to listen to different radio stations on different floors. So I tried duplicating the ‘flow’ I’ve created. For each button I have on a floor I have the IF “Radio station changed” → play radio on Denon 1st Floor, 2nd floor, 3rd floor, etc. The thing is… It will start playing randomly on a floor (I guess where the flow arrives first), since the “IF radio station changed” is always the starter for all Flows…
Can you make the IF “radio changed” also into an AND or THEN, so it can be applied within a flow and not only at the start?
Or is there another solution to use this app in more than 1 flow?
Thanks a lot!
Kan het kloppen dat JOE FM! niet bij de Nederlandse zenders staat?
The Dutch radio station Slam! is a little bitt off. When I play it is plays Slam! 10s but not the regular music station. Can it be adjusted?
Still using your app with great pleasure to avoid Tune In ads and station ID as well as increase speed on my Sonos system.
Would you consider implementing the above example at some point?
