The individual myStrom devices in the network are found via these interfaces
Merci vielmol!
oh, thanks a lot, Chris! I just needed
âhttp://[switch_ip]/relay?state=1â and âhttp://[switch_ip]/relay?state=0â
I can use these with the Logic function in homey in flows and so use the MyStrom Switches anyway.
Well, it is not âstate of the artâ as it would be with your app, but it works for me.
Chris, I do have a UDM Pro (behind a Swisscom Internet Box 4 in the DMZ) and multiple MyStrom Adapters (v1 and v2), so may be I can help you. Iâve used Wireshark with the Display filter âudp.port==7979â and I do see broadcast packets from v2 adapters, but not from v1.
Hi Turbo
First of all, thanks for the help.
The difference between the v1 and v2 switch is not only the lack of power measurement, but also that the v1 switch broadcasts via mDNS (Bonjour) and not via âudp.port==7979â > see
But I still have a basic question: Does the Homey myStrom app work properly for you?
Gruss Chris
At least the status does work and I can enable/disable the switches via Flows, so it seems to work as it should. Iâve added the last v2 switch end of august. So at least end of august I could add the switch without any issues in my setup.
Do you have the support for the LED strips in the planning?
No, I donât have a LED strip to develop & test either
Gruss Chris
@cgHome the new v1.1.2 causes issues on my homey. All my mystrom switches (v1/v2) have an exclamation mark and they show âGerät ist nicht verfĂźgbar - Device error (undefined)â. Additionally I do get for every device on the timeline messages like "MyStromApp - Device myStrom-Switch-xxxxxx discovered - Bonjour > IP: 192.168.20.123 (mac: ABCDEF123456 / type: 101)
I read your notes, do I really have to re-add all devices (except my button?).
Theoretically not, but practically I have no idea what all has been changed internally between SDKv2 and SDKv3 ??. I have imported my switches v1&v2 new (v3), tested and couldnât find any problems (Unfortunately I donât have a separat development system yet, because the new one will be delivered only in December ). So please check first if your FWâs are up to date and then try to re-import only one switch to see if it works properly then.
The message âGerät ist nicht verfĂźgbar - Device error (undefined)â is a âmore detailedâ indication that something is wrong with the communication or the API, with the myStrom devices. Because with the previous versions, it was more or less a blind. But why the interface returns the message âundefinedâ is not quite clear to me, because there should be a more understandable error message.
I added the new hints in the timeline, because in certain installations, the myStrom-Devices are not displayed and it was not clear whether it is the network (UDP problems) or the myStrom-App. The hints are however, per device and start of the app only once. If you do not need them, you can of course also deactivate them.
I hope I could help you
Chris
All devices were already up-to-date. As you suggested I ended up by adding all switches again and it works again, but the mentioned error was truly only because of the upgrade to the newest homey mystrom app. The date of the error and the upgrade correlates. The mystrom button didnât show the error, only the switches.
Thank you anyway for supporting the app and enjoy your new next gen homey .
Btw where can I disable the discovery messages in the timeline during app start?
Pushbuttons have only one-way communication
Where you delete the (iOS or Android) timeline, there you can disable on it
Perfect, wasnât aware of that feature (specific options to disable timeline notifications). But makes sense
Hi Chris,
I am a recent user of a Homey Pro (Early 2023), version 10.0.0-rc.110 and I was happy to see that I can use my myStrom WiFi Buttons directly with Homey. From myStrom I have exclusively 5 Buttons (firmware 2.74.38) in use. My buttons are correctly integrated in my WLAN and I can also see all the devices there, e.g. with the âmyStrom Troubleshooting Toolâ. Yesterday, I also reset all buttons and re-integrated them into my WLAN using the myStrom app.
Currently I have the problem that the myStrom SmartHome App (v1.1.4) of the Homey does not find the devices at all. When I add a new device, I select myStrom-SmartHome â WiFi Button â Connect â it comes the message âFirst install âŚâ â Continue â and then without any delay immediately comes the message âNo new devices were foundâ.
For my WLAN I use an AVM Fritzbox 7590AX incl. 2x AVM 1200AX Repeater with the latest FritzOS. I have read that mDNS must work in the network and have once looked with the app (HE.NET - Network Tools) if I can see something there. It is displayed with any amount of devices / services. From myStrom were unfortunately none of them. If the buttons are active in the network, I can ping them without problems. Is there an idea where the cause of the problem can be?
My Homey has two connections to my network (1x WLAN and 1x LAN). It is the same network segment and I disabled the LAN once to test. The result is unfortunately the same: No button is found.
Thanks for any hints.
Reading educates âŚâŚ
Now itâs official:
ch.mystrom.smarthome has been approved
Gruss Chris
After the update 5 days ago, the consumption display is no longer reset to zero watts when switching off the smart plug. the watt value freezes.
