[APP][Pro] Loops
Thanks.
That made it clear. It was obvious once I saw it. :grinning:
i’m trying to make a ledstrip dim from 0 to 100%.
but i can not find the #iteration value, its not in the list. homey early 2023 v12.0.0
nevermind, i found it. first i have to draw te line from loop to dimmer
You should connect it first to the iterate card :sweat_smile:
Hey Everyone…trying to get my first loop working. I have tried both these Loop cards to run the loop but neither of them work…did I miss something?
Thanks.
The bottom card needs to be replaced with: when loop … Iterates
Where do you get the loops card from?
where did you find the set color during 20 sec?
I do mine this way just holding it in that pattern for 10 seconds before it moves to the next, i did this to pause the lights in the colours before moving to my next set
Been away for a while so just getting back to finish this. Don’t think I have this set up correctly yet…at least it does not work
You would need more steps if you want to fade volume.
Also the iterates card comes with a value tag, so you should use the SET volume card.
I just picked 5 for illustration point. I actually need 10 “volume up” keys to get the volume where I want on the Nvidia Shield.
Why would I use the value tag when I used a variable? And how does that fix the loop so it actually will execute?
I can’t test it right now as I moved to Home assistant.
Hi everyone,
I’m gonna request Homey to delete this app.
Hi @Menno_van_Hout please do not request that !
I am very grateful this has been created and have been using this successfully for now 2 years. It would be very sad to have this deleted and my flows not be able to take advantage of what you have created ! :pensive:
Hello, i have done it the same way as you, but when it reaches the end it just stop. how to get it to keep looping/going?
See below, hope that helps make more sense
Thanks i will try
Hilsen Claus Jacobsen
If I understand the cards correctly, it is only possible to loop a set number of times? I’d like to loop indefinetaly until a condition occour. Is that possible?
Yes & no, My idea was to preventpeople for making a lot of infite loops crashing their Homey.
But what you can do:
Run a loop for 100 times, use the on loop end card to start it again!.
Ok, in that case this app is not for me now. I’ll just loop a flow instead in the meantime.
