[APP][Pro] Insights Graphs
Today I installed the Insights Graphs app from the Homey official store. However I don’t get the app to work. In the Homey app the new app is visible, but it does not show any flowcards, screen appears to stay blank. On the Homey web the app does not show up at all in the installed apps. What am I doing wrong?
I installed it a few days ago to test something, it works fine.
But you don’t see flow cards in the mobile app flow editor, because the app has one flow card, and it’s for advanced flow only:
That’s why you don’t see it in the mobile app standard flow editor.
The browser is fooling you and presents cached data.
I guess you’d force refresh the browser, or open the web app in a private tab.
Thanks, that was it! Did not read good enough. Now it works.
I haven’t got a homey (pro) yet, but before purchasing I need to know if it is capable of creating customized graphs where the X and Y axis reference can be chosen independent, for example “load” on the X axis, and “temperature” on the Y axis, preferably plotted as dots in a graph. Is this possible with “insights graps”? As far as I see there are only possibilities where a reading is noted/plotted as a function of time?
This is / should be possible (as of yesterday) with the DataVista dashboard widget.
In my timeline on my homey app every 3 hours I get a strange error “This app is not supported anymore” No further info. Is it about an app I use within homey, or the homey app itself. No idea. I have no flows running with a 3 hour interval. How to get more info from this error ? It started a few months ago.
Thanks for any suggestion to further investigation.
Check your installed apps for the same icon as the timeline notification. That would be the app that the developer has decided not to support anymore.
Found your app installed Insights Graphs App for Homey | Homey
See [APP][Pro] Insights Graphs - #183 by Menno_van_Hout
Great thanks for helping me out.
I don’t know if there is still dev support on this app, but I’ll try it anyway :blush:.
Is it possible to change the flow cards so that we can choose a title for a graph ourselves?
I really like the possibilities of this app. I want to use it to display multiple graphs under each other.
Right now, a graph is named automatically according to the variable title. But if you have multiple devices with a “Power” variable, alle graphs are named “Power”.
Would be great if there would be an option change the naming to your own choice.
That could be possible, I hope I’ll remember to add it for after my holidays.
Insight graph failure today.
Today I am facing an issue with your Insight Graph APP v2.0.5
It is running on Homey SHS v.13.4.1.
When I try to run a graph the error raised is: “getaddrinfo EAI_AGAIN quickchart.io”
The diagnostic report: 808fd467-3cca-46d2-8ab6-b7867cbbcf88
Pls let me know
That seems to be a local network issue your network couldn’t resolve the url.
But that’s not something I can solve, your own local network doesn’t resolve the url
Yes, I have found the issue in my Internet connection then.. Now it is ok. Thank you for the answer
Glad to hear you solved it!
