[APP][Pro] ID Lock Next
2.6.10 is out — please update, then restart the app (More → Apps → ID Lock Next → Restart) and wait a couple of minutes. This version reads the ID from your lock and hands it to Homey. Afterwards, open the app’s settings → Diagnostik → “Ladda ner rapport (JSON)” and paste it here — the report you sent last time never reached me, so the file is the safer route. One line in it tells us whether Homey accepted the ID, and then whether the update is worth trying.
Here is the report,
“appVersion”: “2.6.10”,
“generatedAt”: 1790062647619,
“device”: {
“name”: “Ytterdörr”,
“model”: “ID Lock 150/202”,
“protocol”: “zwave”,
“firmware”: “1.5”,
“available”: true,
“lastSeenAt”: null
“state”: {
“locked”: true,
“doorOpen”: false,
“battery”: 80
“health”: [
“key”: “connection”,
“status”: “green”,
“label”: “Anslutning”,
“detail”: “Ansluten”
“key”: “battery”,
“status”: “green”,
“label”: “Batteri”,
“detail”: “80 %”
“key”: “sync”,
“status”: “green”,
“label”: “Synkronisering”,
“detail”: “Uppdaterad”
“sync”: {
“running”: false,
“queued”: 0,
“history”:
“logs”: [
“[DEBUG] (zwave) firmware diagnostics {“liveModule”:null,“livePanel”:null,“recordedVersion”:null,“firmwareId”:null,“firmwareUpdateCc”:true,“zwSettings”:[“zw_group_1”,“zw_application_version_1”,“zw_application_sub_version_1”],“commandClasses”:[“COMMAND_CLASS_ASSOCIATION”,“COMMAND_CLASS_ASSOCIATION_GRP_INFO”,“COMMAND_CLASS_BATTERY”,“COMMAND_CLASS_CONFIGURATION”,“COMMAND_CLASS_DEVICE_RESET_LOCALLY”,“COMMAND_CLASS_DOOR_LOCK”,“COMMAND_CLASS_FIRMWARE_UPDATE_MD”,“COMMAND_CLASS_MANUFACTURER_SPECIFIC”,“COMMAND_CLASS_NOTIFICATION”,“COMMAND_CLASS_POWERLEVEL”,“COMMAND_CLASS_SECURITY”,“COMMAND_CLASS_USER_CODE”,“COMMAND_CLASS_VERSION”,“COMMAND_CLASS_ZWAVEPLUS_INFO”]}”,
“[WARN] (zwave) firmware fail-open {“liveModule”:null}”,
“[INFO] (zwave) VERSION_REPORT {“Z-Wave Library Type (Raw)”:”“,“Z-Wave Library Type”:3,“Z-Wave Protocol Version (Raw)”:”“,“Z-Wave Protocol Version”:4,“Z-Wave Protocol Sub Version (Raw)”:”“,“Z-Wave Protocol Sub Version”:5,“Firmware 0 Version (Raw)”:”“,“Firmware 0 Version”:1,“Firmware 0 Sub Version (Raw)”:”“,“Firmware 0 Sub Version”:5,“Hardware Version (Raw)”:”“,“Hardware Version”:1,“Number of firmware targets (Raw)”:”“,“Number of firmware targets”:1,“vg (Raw)”:”“,“vg”:[{“Firmware Version (Raw)”:”“,“Firmware Version”:1,“Firmware Sub Version (Raw)”:”“,“Firmware Sub Version”:1}],“Variant Group”:[{“Firmware Version (Raw)”:”“,“Firmware Version”:1,“Firmware Sub Version (Raw)”:”“,“Firmware Sub Version”:1}]}”,
“[DEBUG] (zwave) firmware diagnostics {“liveModule”:“1.5”,“livePanel”:null,“recordedVersion”:null,“firmwareId”:null,“firmwareUpdateCc”:true,“zwSettings”:,“commandClasses”:[“COMMAND_CLASS_ASSOCIATION”,“COMMAND_CLASS_ASSOCIATION_GRP_INFO”,“COMMAND_CLASS_BATTERY”,“COMMAND_CLASS_CONFIGURATION”,“COMMAND_CLASS_DEVICE_RESET_LOCALLY”,“COMMAND_CLASS_DOOR_LOCK”,“COMMAND_CLASS_FIRMWARE_UPDATE_MD”,“COMMAND_CLASS_MANUFACTURER_SPECIFIC”,“COMMAND_CLASS_NOTIFICATION”,“COMMAND_CLASS_POWERLEVEL”,“COMMAND_CLASS_SECURITY”,“COMMAND_CLASS_USER_CODE”,“COMMAND_CLASS_VERSION”,“COMMAND_CLASS_ZWAVEPLUS_INFO”]}”,
“[WARN] (zwave) firmware fail-open {“liveModule”:“1.5”}”
Hi Göran — thanks, that report answers the main question.
The app has already handed Homey the ID. That happened on the first start after you updated, so there’s nothing left to prepare.
Could you simply try the firmware update once and tell me what happens? If it fails again, a screenshot of the error is all I need.
Two notes, in case you wonder why I can’t just tell you:
  • Homey stores that ID in a field it doesn’t show back to the app, so from here I can’t see whether it accepted it. Only an update attempt can.
  • If it still refuses to start, that is not your lock and not something you can fix. Athom has the full report and the case is with them (issue #461). Your lock keeps working exactly as it does now on firmware 1.5.
And when you get around to mounting one of the new locks, trying the update on that one is still the most interesting test of all — a freshly added lock may get the ID recorded properly from the start.
Hello
Sorry but same result
“appVersion”: “2.6.11”,
“generatedAt”: 1790077680253,
“device”: {
“firmware”: “1.5”,
“available”: true,
“lastSeenAt”: null
“state”: {
“locked”: true,
“doorOpen”: false,
“battery”: 80
“health”: [
“status”: “green”,
“key”: “battery”,
“status”: “green”,
“label”: “Batteri”,
“detail”: “80 %”
“key”: “sync”,
“status”: “green”,
“sync”: {
“running”: false,
“queued”: 0,
“history”:
“logs”: [
“[DEBUG] (zwave) firmware diagnostics {“liveModule”:null,“livePanel”:null,“recordedVersion”:null,“firmwareId”:null,“firmwareUpdateCc”:true,“zwSettings”:[“zw_group_1”,“zw_application_version_1”,“zw_application_sub_version_1”],“firmwareIdStampedFor”:“1.5”,“zwFirmwareIdSetting”:null,“commandClasses”:[“COMMAND_CLASS_ASSOCIATION”,“COMMAND_CLASS_ASSOCIATION_GRP_INFO”,“COMMAND_CLASS_BATTERY”,“COMMAND_CLASS_CONFIGURATION”,“COMMAND_CLASS_DEVICE_RESET_LOCALLY”,“COMMAND_CLASS_DOOR_LOCK”,“COMMAND_CLASS_FIRMWARE_UPDATE_MD”,“COMMAND_CLASS_MANUFACTURER_SPECIFIC”,“COMMAND_CLASS_NOTIFICATION”,“COMMAND_CLASS_POWERLEVEL”,“COMMAND_CLASS_SECURITY”,“COMMAND_CLASS_USER_CODE”,“COMMAND_CLASS_VERSION”,“COMMAND_CLASS_ZWAVEPLUS_INFO”]}”,
“[DEBUG] (zwave) firmware diagnostics {“liveModule”:“1.5”,“livePanel”:null,“recordedVersion”:null,“firmwareId”:null,“firmwareUpdateCc”:true,“zwSettings”:,“firmwareIdStampedFor”:“1.5”,“zwFirmwareIdSetting”:null,“commandClasses”:[“COMMAND_CLASS_ASSOCIATION”,“COMMAND_CLASS_ASSOCIATION_GRP_INFO”,“COMMAND_CLASS_BATTERY”,“COMMAND_CLASS_CONFIGURATION”,“COMMAND_CLASS_DEVICE_RESET_LOCALLY”,“COMMAND_CLASS_DOOR_LOCK”,“COMMAND_CLASS_FIRMWARE_UPDATE_MD”,“COMMAND_CLASS_MANUFACTURER_SPECIFIC”,“COMMAND_CLASS_NOTIFICATION”,“COMMAND_CLASS_POWERLEVEL”,“COMMAND_CLASS_SECURITY”,“COMMAND_CLASS_USER_CODE”,“COMMAND_CLASS_VERSION”,“COMMAND_CLASS_ZWAVEPLUS_INFO”]}”,
/Göran
(attachments)
That means i have to accelerate the work with next look :slight_smile:
Hi Göran — thanks for testing, and that is the answer, even if it isn’t the one we wanted.
Your report shows the app handed Homey the ID, Homey accepted it without complaint, and the update still refuses to start. That confirms the gap is inside Homey itself, in a place no app can reach. I’ve added your result to the report with Athom — it actually helps them, because “the value was written and Homey ignored it” narrows down exactly where their fix belongs.
So please stop retrying on this lock. It cannot succeed at the moment, and it only costs batteries. Everything else keeps working exactly as it does now on firmware 1.5, and 1.6 is a small feature update you are not really missing out on.
One thing is still worth doing whenever you get to it: try the update on your newly mounted lock. It will be freshly added to Homey, so it may get the ID recorded properly from the start — and if it does, we will know that re-pairing fixes this lock too. No rush at all.
Thank you for the patience through all of this. Your reports are what turned “firmware updates don’t work” into a precise, reproducible bug report, and the fixes along the way (the wrong lock firmware version, unlocks showing as unknown codes, duplicate events) all came out of your logs.
Hello
Greate to help, i´ll come back when the other lock is installed.
Do you know the difference between the Z-Wave module in the black box and the one in the white box?
HI @c0d3x
I have tried one time to remove battery and z-wave module.
Should i try more times or try to re include lock again to check if something went wrong when including?
I know i have updated to latest possible FW via the ID lock app on my phone.
Hi @Kraakenes — thanks for the screenshot. You’ve already done the right things: one re-seat of the module is enough, and your lock firmware is up to date via ID Lock’s app. Please don’t repeat the re-seat, and don’t re-add the lock yet — neither is likely to change this, and re-adding costs you your Flows and user setup.
The “0.0.0” is what your Z-Wave module reports when asked for the lock’s own firmware version. My warning says this means codes never reach the door, but that’s too strong: I’ve seen another lock report 0.0.0 while working normally. I’ll soften that message in the next version.
So let’s test whether your lock actually works through Homey:
  1. Lock and unlock it from Homey — does the door respond?
  2. Add a test PIN in the app, wait until it shows as synced, then try it on the keypad.
  3. Tap “Sjekk koder på låsen” on the Users page — does it list the codes in your lock?
If the test PIN opens the door, everything is fine and you can ignore the warning — it’s only the version report that’s odd. If lock/unlock works but the PIN from the app never works at the door, then the module really isn’t reaching the lock, and it’s worth contacting ID Lock support.
Two small things: is it an ID Lock 150 or 202? The 202 may report its version differently. And “Batteri: Ukjent” is normal right after a restart — the lock sends its battery level after an unlock, so it should appear once you’ve used it.
Hi @c0d3x thanks for swift reply.
I was away a few days hunting so a bit slow reply from my side. I now see that the “error” has cleared and i also observed that the homey “eventlogg” display door unlocked by unknown (kode1)(pin) so it seems everything is working now. It just needed some time.
I just tested i as was also able to pull already added codes to the door-lock into the app so i think everything is as it should now. Great work and nice app.
Hi, @c0d3x
I am having some issues that might be related to the app.
Ever so often my id lock 150 will get the status not reachable. Restarting the app fixes this 10/10 times. So i think there is something with the integration you might want to look into.
I have generated a diagnostic report while the lock was reachable
7b2baaa0-76cb-43a6-9476-de4f7d82eb2e
And one some hours later when everything is working it that in any means help
014d6e17-fecb-40c0-a1c7-fee3050b1bdb
Thanks @Kraakenes. The report you sent while it was stuck showed what’s going on.
When the lock leaves two commands in a row unanswered, the app marks it “not responding”. Homey then blocks every command and flow to a device in that state, so the only way back was the lock sending something on its own. If it stayed quiet, it stayed “not responding” until the app restarted. That’s why a restart always fixed it.
2.6.14 (on Test now) fixes this:
  • While the lock is marked “not responding”, the app keeps checking it in the background (after 1, 2, 5 and 10 minutes, then every 30) and makes it available again as soon as it answers. No restart needed.
  • Commands that fail while Homey is backing up its Z-Wave chip at night no longer count against the lock.
  • Every missed command and every check is now logged, so if it happens again, a diagnostics report will show when and why.
Your log also shows the app restarting at exactly 01:00 and 21:00 on some days. If that’s a flow you set up to work around this, you can switch it off once you’ve updated.
If it still shows “not responding” for more than a few minutes after updating, send a diagnostics report from the app while it’s in that state.
Hi, @c0d3x
I have turned of the restart flows and will monitor but it should be fixed now.
Thanks a million
Lately when pulling codes from the door, it rarely manages to check more than 2-4 codes of the 7 I have. Just me? Any solution? For what it’s worth, adding a new code still works.
Not just you, @Tore_Th, and thanks for flagging it. When the lock answers a code question late, Homey hands that late answer to the next question the app asks, so every answer after it lands one slot off. The check rightly refuses answers about the wrong slot (that’s what caused the ghost codes back in August), but it counted each refusal as a failure and gave up after three in a row. That’s why it stopped after 2–4 codes.
2.6.15 (on Test now) fixes it. When an answer is about the wrong slot, the check waits a moment and asks again, which puts it back in step, and synced codes it still couldn’t read get a second try at the end. On a slow lock a check can take a minute or two.
If it still stops early after updating, send a diagnostics report for the app right after a code check. It now includes what the check saw for each slot.
