Hmm, I do believe the code is working, but let’s try changing it. Here is diagnosis from v18 with no changes(still failing 1/7):
“appVersion”: “2.6.18”,
“generatedAt”: 1794551453781,
“device”: {
“name”: “IDLock”,
“model”: “ID Lock 150/202”,
“protocol”: “zwave”,
“firmware”: “1.6”,
“available”: true,
“lastSeenAt”: 1794537622931
“state”: {
“locked”: true,
“doorOpen”: false,
“battery”: 55
“health”: [
“key”: “connection”,
“status”: “green”,
“label”: “Tilkobling”,
“detail”: “Tilkoblet”
“key”: “battery”,
“status”: “green”,
“label”: “Batteri”,
“detail”: “55 %”
“key”: “sync”,
“status”: “green”,
“label”: “Synkronisering”,
“detail”: “Oppdatert”
“sync”: {
“running”: false,
“queued”: 0,
“history”:
“logs”: [
“[DEBUG] (zwave) firmware diagnostics {“liveModule”:null,“livePanel”:null,“recordedVersion”:null,“firmwareId”:null,“firmwareUpdateCc”:true,“zwSettings”:[“zw_group_1”,“zw_application_version_1”,“zw_application_sub_version_1”],“firmwareIdStampedFor”:“1.6”,“zwFirmwareIdSetting”:null,“commandClasses”:[“COMMAND_CLASS_ASSOCIATION”,“COMMAND_CLASS_ASSOCIATION_GRP_INFO”,“COMMAND_CLASS_BATTERY”,“COMMAND_CLASS_CONFIGURATION”,“COMMAND_CLASS_DEVICE_RESET_LOCALLY”,“COMMAND_CLASS_DOOR_LOCK”,“COMMAND_CLASS_FIRMWARE_UPDATE_MD”,“COMMAND_CLASS_MANUFACTURER_SPECIFIC”,“COMMAND_CLASS_NOTIFICATION”,“COMMAND_CLASS_POWERLEVEL”,“COMMAND_CLASS_SECURITY”,“COMMAND_CLASS_USER_CODE”,“COMMAND_CLASS_VERSION”,“COMMAND_CLASS_ZWAVEPLUS_INFO”]}”,
“[WARN] (zwave) firmware fail-open {“liveModule”:null}”,
“[INFO] (zwave) slot sweep aborted early {“read”:10,“stopped”:“silent”,“resynced”:[2,3,5,6,9,10,11],“mismatched”:,“silent”:[7,12,13,14],“silentWhy”:{“7”:“timeout”,“12”:“timeout”,“13”:“timeout”,“14”:“timeout”},“strays”:[[2,1],[3,2],[5,4],[6,5],[7,6],[9,8],[10,9],[11,10],[12,11]],“late”:,“secondChance”:{“tried”:[7],“answered”:},“ms”:[3452,6577,2851,3009,8349,7110,17174,9380,9557,6690,9574,14772,15056,15076]}”
And then after changing slot 2 (now no errors!):
“generatedAt”: 1794551761122,
“device”: {
“name”: “IDLock”,
“firmware”: “1.6”,
“available”: true,
“lastSeenAt”: 1794551713730
“state”: {
“locked”: true,
“doorOpen”: false,
“battery”: 55
“health”: [
“status”: “green”,
“key”: “battery”,
“status”: “green”,
“label”: “Batteri”,
“detail”: “55 %”
“key”: “sync”,
“status”: “green”,
“sync”: {
“running”: false,
“queued”: 0,
“lastSyncAt”: 1794551583150,
“history”: [
“operation”: {
“id”: “mwelobio-588owp”,
“type”: “set_code”,
“slot”: 2,
“label”: “Sett kode for Stef (plass 2)”
“status”: “success”,
“attempts”: 1,
“updatedAt”: 1794551583127
“logs”: [
“[INFO] (zwave) slot sweep aborted early {“read”:10,“stopped”:“silent”,“resynced”:[2,3,5,6,9,10,11],“mismatched”:,“silent”:[7,12,13,14],“silentWhy”:{“7”:“timeout”,“12”:“timeout”,“13”:“timeout”,“14”:“timeout”},“strays”:[[2,1],[3,2],[5,4],[6,5],[7,6],[9,8],[10,9],[11,10],[12,11]],“late”:,“secondChance”:{“tried”:[7],“answered”:},“ms”:[3452,6577,2851,3009,8349,7110,17174,9380,9557,6690,9574,14772,15056,15076]}”,
“[INFO] (zwave) code write verify {“userId”:2,“verdict”:“confirmed”}”,
“[INFO] (zwave) slot sweep aborted early {“read”:7,“stopped”:“silent”,“resynced”:[2,3,4],“mismatched”:,“silent”:[5,6,7],“silentWhy”:{“5”:“timeout”,“6”:“timeout”,“7”:“timeout”},“strays”:[[2,1],[3,2],[4,3],[5,4]],“late”:,“secondChance”:{“tried”:[5,6,7],“answered”:[5,6,7]},“ms”:[3517,5769,9660,10060,17148,15044,15005]}”
