Hello
Thanks for quick respons, i am very interested in getting this working
- Yes it works fine with lock and unlock. “Uppdatera från låset” i cant find, i think you mean “Kontrollera koder på låset” under section User, or? And that works. “Låsets firmware” shows 1.0.1, i think we discussed it previously.
- I´m attaching the diagnostics report below
- Security i S0, and FYI it connect trough another device
If there´s anything else I can do, just let me know
/Göran
“appVersion”: “2.6.8”,
“generatedAt”: 1789550453831,
“device”: {
“name”: “Ytterdörr”,
“model”: “ID Lock 150/202”,
“protocol”: “zwave”,
“firmware”: “1.5”,
“available”: true,
“lastSeenAt”: 1789549943088
“state”: {
“locked”: true,
“doorOpen”: false,
“battery”: 85
“health”: [
“key”: “connection”,
“status”: “green”,
“label”: “Anslutning”,
“detail”: “Ansluten”
“key”: “battery”,
“status”: “green”,
“label”: “Batteri”,
“detail”: “85 %”
“key”: “sync”,
“status”: “green”,
“label”: “Synkronisering”,
“detail”: “Uppdaterad”
“sync”: {
“running”: false,
“queued”: 0,
“history”:
“logs”: [
“[INFO] (zwave) VERSION_REPORT {“Z-Wave Library Type (Raw)”:”“,“Z-Wave Library Type”:3,“Z-Wave Protocol Version (Raw)”:”“,“Z-Wave Protocol Version”:4,“Z-Wave Protocol Sub Version (Raw)”:”“,“Z-Wave Protocol Sub Version”:5,“Firmware 0 Version (Raw)”:”“,“Firmware 0 Version”:1,“Firmware 0 Sub Version (Raw)”:”“,“Firmware 0 Sub Version”:5,“Hardware Version (Raw)”:”“,“Hardware Version”:1,“Number of firmware targets (Raw)”:”“,“Number of firmware targets”:1,“vg (Raw)”:”“,“vg”:[{“Firmware Version (Raw)”:”“,“Firmware Version”:1,“Firmware Sub Version (Raw)”:”“,“Firmware Sub Version”:1}],“Variant Group”:[{“Firmware Version (Raw)”:”“,“Firmware Version”:1,“Firmware Sub Version (Raw)”:”“,“Firmware Sub Version”:1}]}”,
“[INFO] (zwave) lock event {“kind”:“unlock”,“method”:“manual”,“user”:“Manuell”}”,
“[INFO] (zwave) lock event {“kind”:“lock”,“method”:“manual”,“user”:“Manuell”}”,
“[INFO] (zwave) lock event {“kind”:“unlock”,“method”:“pin”,“user”:“Göran”}”,
“[INFO] (zwave) lock event {“kind”:“unlock”,“method”:“pin”,“user”:“Okänd (kod -59)”}”,
“[INFO] (zwave) slot sweep complete {“read”:12,“occupiedSlots”:[1,3,5,8],“mismatched”:[2,4,7,9,11,13,15,17,19,21,23,25],“ghostsCleared”:}”,
“[INFO] (zwave) slot sweep aborted early {“read”:3,“mismatched”:[2,4]}”,
“[INFO] (zwave) slot sweep complete {“read”:13,“occupiedSlots”:[1,3,5,9],“mismatched”:[2,4,6,8,10,13,15,18,20,22],“ghostsCleared”:}”
