[APP][Pro] ID Lock App (v2.0.0)
I’m so happy you release an update for HP23!! You made my day. Thank you for your effort.
I will have to look into this issue after my holidays (end of August). Do note that I don’t have a working IDLock setup, so debugging is taking some time.
At this moment I am not planning to extend support for the Zigbee module nor for the IDlock 202, without support from IDlock itself. The required effort (time and investment into a working setup) to add support for the Zigbee module (given also the required additional implementation into Homey’s Zigbee-driver / Zigbee-cluster definition) is simply too big.
If you want to have the Zigbee module or the IDLock 202 supported in this app, please contact IDLock directly. They know how to contact me.
Very good. Enjoy your holiday! Thanks
@TedTolboom I´ve sent IdLock a request for support as well. Guess @Bananfluen already has done this. Currently I´m not very happy with the 202 model. It´s pretty far away from being a “smart lock” when it lacks decent support in systems like Homey and Futurehome (beeing a Norwegian, this system has worked well with the previous versions of the lock).
I havent sent any request ti IdLock myself since i have the 101 (first) model. This worked fine on the “old” homey.
I am struggling with the same as you @Bananfluen. I really hope it is possible to find out some more on what is causing this. I just moved my devices over from Futurehome smarthub, and really need to get my smartlock working with Homey Pro.
Enjoy your holidays Ted.
If you have more than one lock, how to configure per. lock? Someone opened the door etc is set via the configuration, but that only works for the first added lock?
same problem as Bananafluen. I have a IDlock 101… Will test it on my IDlock 150.
Same problem with my idlock 101! Includes ok, but capability listener problem!
(Homey pro 2023)
works with IDlock 150. but the app says it´s a IDlick 101 after installation… but works fine, so far no issues.
Still the same problems on IDlock 101 as bananafluen and Bjarne_Lund
Does this app support adding, changing and removing door codes?
Or is there a good way to manage the door codes remotely?
Not as it is now with the IDlock 150… I think that is a safety thing.
I could do this in Samsung Smartthings with RBoy integration and app.
Can’t see why it should not be possible to do this, as the z-wave device has options for it.
Hi, i have several 150 locks and one 202.
Are there any plans on adding the 202 into the app as well?
And ofcourse zigbee, module
Hi.
I have an ID Lock 150 which I have included to my new HP23. Problem is that after I included this, the whole z-wave network is stopping to respond for 2-5 minutes after I lock/unlock the door.
I have short distance from my hub to the ID lock, and about 30 ac powered z-wave devices in my house, so the mesh should be good.
Can this be caused by a faulty z-wave chip in the lock? or maybe it is related to this problem: Homey pro 2023 - zwave too much traffic error?
Will it b any update on this app ?
My ID Lock 150 works great with Homey for locking and unlocking via the Homey app.
But I can´t get it to work in flows. I have the Z-wave module. Anyone with simular problems? Any ideas how to fix this?
What support do you lack from IdLock regarding zigbee support?
Home assistant has support for Idlock with Zigbee. Therefore I guess they have everything in place.
Thx for all the good work with this app!
I have the 150 and no problems With the flows
@TedTolboom , I’m talking to ID Lock support now, and will make sure to tell them to contact you for full 202 support in your app. I have also found out that 202 can be added as 150, and lock/unlock and contact alarm will work,
