[APP][Pro] Homewizard 🧙‍♂️
Did you restart the HomeWizard Homey app too?
Now other device is losing connection:
2024-01-26T18:06:31.619Z [err] [ManagerDrivers] [Driver:energy_socket] 3c39e7281804 FetchError: request to http://192.168.2.13/api/v1/data failed, reason: read ECONNRESET
at ClientRequest. (/app/node_modules/node-fetch/lib/index.js:1491:11)
at ClientRequest.emit (node:events:517:28)
at Socket.socketErrorListener (node:_http_client:501:9)
at Socket.emit (node:events:517:28)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
type: ‘system’,
errno: ‘ECONNRESET’,
code: ‘ECONNRESET’
My socket is reachable by other instances like home assistant, by the web browser, it’s also showing up in mdns.
Weet het niet meer….
Homey rebooted?
Did a PtP just now, didn’t help unfortunately
92f5cd8e-0c17-4d91-a72d-2e2cd2e161a4
Then I am out of options.
There was a Unifi update and probably with the reboot all the network settings were reset. All the plugs show up again in homey. Probably a network issue at all. Thanks for your replies!
Hopefully other people (like Lars) can also solve their problems
Thx for confirming that. Which proofs my struggle with these mDNS odd problems. Not one single user WiFi network is the same. To many factors impact this behavior.
Beta/Test:
v3.3.3
  • KWH Meters SDM230 & SDM630 added support for Voltage & Amp (requires SDMxxx firmware 4.06+)
  • Bug fix SDM630
  • Updated product brandnames and internal mDNS discovery matching
Hi!
After using the Homewizard app flawless on my HP19 for quite some time, since I migrated to HP23, I encounter a lot of connection problems (econnreset / socket hang up). I read about the possibility of wrong wifi configuration, but it is exactly the same a on my HP19.
I migrated to my HP23 with a backup restore; could that be causing issues? I’m not using the beta software. I have the following HW hardware: P1, Water sensor, 1fase power meter and 6 sockets.
Thanks!
Greetings, Bram
Nope, to me it sounds wifi connection issues with your HP2023. Maybe move it a bit? Myself migrated from a Homey Early 2016 to HP2023 a few months ago via restore backup like you.
Its either the reliability of the wifi connection of your HP2023 or your devices keep getting new ip addresses from your DHCP server (i.e. internet router).
Perfect :blush:. Thank you .
Thx for confirming the changes are as expected. :+1:t2:
Hello, it seems that i can’t add the Huawei converter to the app…
What could be the problem?
thx in advance!
Grtz
That information is only available in Homewizard Energy Cloud and is not exposed to the P1 wifi dongle. Sorry can’t help you with that.
Perhaps this works?
Hi Jeroen,
This app unfortunately doesn’t work either, I can’t add the inverter to both the Huawei app and the homewizard app
Thanks anyway!
Homewizard doesnt expose your inverter via the Local API so I dont have access via my Homewizard Homey app code. If you really want this information in Homey you have to put a kwh meter between your inverter and energy grid. Sadly I can’t help you any further with this.
If you have an energy+ account you can add inverters of different brands under the devices tab.
I just managed to add the inverter but it shows as offline.
I think the problem lies with Huawei
thx!
I know, but that is in Homewizard Energy+ Cloud. That information is not known locally via P1 wifi dongle.
v3.3.5 (beta / test)
  • Finetuning
  • Lowered CPU footprint (polling Energy sockets set to 10s and not 2s)
