Well if you can’t see the P1 in that app, then Homey can’t find it either.
Try to powercycle the P1 (again, yes I know) maybe for a 1 minute to be sure it has no power via usb and/or your smart meter connector. When you power up see if it starts to show up in that mDNS browser app again, only then it will work with Homey.
So mDNS not working makes finding it hard for Homey.
See if you can make the old ip static for the P1 what it was (click on red marker in P1 it will throw error and ip address). Reserve that address in your UDM and it should get back up in Homey.
Raised a support ticket with Homeward but don’t expect a solution soon.
Click on red triangle only tells it is not available.
I looked into the routers disconnected devices and found the “old” device. I can not see old ip but what is confusing me is that the “new” P1 and old P1 have different MAC. How is that possible?
That must be the reason that the leased IP not is working.
Then I am out of options as well. Downside of test/beta firmware P1 user.
Got the same problem (no mdns traffic from P1).
At least homewizard dev team is made aware.
