[APP][Pro] HomeWizard Link
Link your Link with Homey.
The HomeWizard Link app supports the following:
  • Color light bulb
  • CO detector
  • Door sensor
  • Water leakage detector
  • Smoke detector
  • Multi white light bulb
  • Thermometer
If you have any other devices that aren’'t supported, please mention here which device you would like to have added.
Note that the app uses polling to the cloud API every 4 seconds. The official Android app does this every 2 seconds, but this is way too much for the Homey app which is running 24/7. The Links do have a local API, but they don’‘t expose their IP in the cloud API so I don’‘t know how else I would build that (MAC discovery doesn’'t work)
The app also supports the use of multiple Links, as long as they’'re linked to the same HomeWizard account.
If you encounter any issues, please let me know
Device support
If you have any of the following devices:
  • Wall switch converter
  • Siren
  • Socket
  • Plug-in dimmer
  • Doorbell
Or any other device that works with the HomeWizard Link app, please let me know in the replies below so that I can add support for it.
Version 1.0.2
  • Fix icons
I’m preparing the app for publishing to Live now. The only thing I have to add is a repair view so that it would be possible to change the login. If you encounter any issues with the app or have any of the devices listed here, please let me know.
Version 1.0.3
  • Added repair view
Version 1.0.4
  • Added tags for app store visibility
Version 1.0.5
  • Minor improvements
There seems to be an issue with the app where sometimes it makes the device unavailable and then can’t log in on the Link anymore. It happens completely randomly (sometimes it works for a few days and sometimes it takes only a few hours for it to appear), making it hard to find the issue. If you have this issue, restarting the app fixes it temporarily. I will try to look deeper into the issue tomorrow
I have identified the issue and a fix is available on GitHub. It’'s only with the contact sensor, the light should work fine. I will publish the new version later today
I have published a fix for the door sensor issue. Update to 1.0.6 if you’'re experiencing issues where the door sensor goes offline and doesn’t get back online
Version 1.0.6
  • Fix disconnect issue with the door sensor
  • Added localized device unavailable messages.
Version 1.0.7
  • Added settings page for retrieving home endpoint data
@smarthomesven
Water detector, smoke detector and White light bulb are in the house. I’m available in case you need more device info or a person to test this setup with.
(Not sure if the bulb is still working :grimacing:).
Cheers, Jackass
Try installing the test version of the app and adding the color bulb. Is the bulb found by the app? For the water sensor and the smoke detector you can open the app settings (More→Settings→HomeWizard Link in the mobile app or Settings→HomeWizard Link→Configure in the web app) and load the configuration data. Send this data in a DM. Do not post it publicly here because it might contain IDs, MAC address and other identifiers stored on your Link.
The test version now supports the White light bulb, smoke detector and water detector
It also supports the battery alarm for the door sensors. If you want to use it, remove your door sensors form Homey first and then add them again.
If you experience any issues with the app, please let me know.
Version 1.1.3
  • Added an option to easily send the configurations privately
I’ve ordered the CO detector so that one will also be added soon.
Version 1.2.0
  • Added CO detector
  • Added battery alarm to existing door sensor devices
  • Fixed Link online/offline detection
It took some time, but the CO detector finally arrived half an hour ago. I’ve added support for it in the app, let me know if you encounter any issues
