[APP][Pro] HomeKit Device Bridge
Test V 2.2.2
  1. Added Apple Home support for compatible ONVIF cameras connected to Homey over RTSP. HomeKit Secure Video (HKSV) recording can be enabled per camera when motion detection is available.
  2. HomeKit Device Bridge can detect compatible stream changes in UniFi Protect and refresh the affected camera without reinstalling the app or resetting its Apple Home pairing.
  3. Live views and snapshots can reuse an active HKSV stream, reducing duplicate camera connections. The app falls back to a direct connection when needed.
  4. When a camera provides multiple streams, the app can select a compatible native H.264 substream without re-encoding video.
  5. Improved recording recovery after temporary connection and MP4 fragment errors. Brief gaps in motion no longer end clips prematurely.
  6. Removed the app’s fixed HKSV camera count limit and added a performance warning in Settings. Memory and live-stream safeguards remain in place.
  7. Expanded anonymous camera diagnostics with memory usage, packet queues, and recording errors.
Test Version 2.2.3
  • Fixed an issue where a failed or stalled camera stream could cause other cameras to show “No Response” in Apple Home.
  • Added per-camera status in Settings so you can see whether the camera is unavailable in Homey, unpublished in Apple Home, or failing to stream or record.
  • Improved recovery for ONVIF cameras whose video streams become available after startup, while preserving existing Apple Home pairings.
  • Improved HomeKit Secure Video compatibility with cameras that advertise different H.264 levels for the same recording resolution.
  • Fixed a startup issue that could leave the bridge stuck after Homey ran out of storage. The bridge can now retry once space becomes available, and failed writes preserve the last saved HomeKit data.
  • Improved Apple Home discovery and accessory cleanup when network announcements fail.
