Good morning Erikje, I just tryed the new camera function. It shows offline all the time also the camera is actualy online.
And I miss a on/off switch because not all cameras are switched on all the time.
I wish you a nice weekend.
Hi Dietrich,
This will be a fun one to figure out. The tricky part is still that you’re using a different app for your camera than I am. HomeOverview actually uses the standard Homey Video option, so this should really be a general thing.
But now, for example, I installed the ONVIF app myself and see my camera showing as offline there as well, but apparently when I tap further into the camera, the livestream suddenly shows up. Is this happening to be the case for you too?
Which app do you use for your camera? Maybe I can check if something specific is happening there or something.
Hi Erikje,
the camera is conected via the Tuya app and is perfectly displayed with the standard camera widget from homey.
I also tryed waiting for some minutes, but no video appeared.
Just to be sure: clicking on the camera opens the camera detail page. Are you unable to see the stream there as well?
Yes, I also tryed that.
Could you try testing with v1.12.1? Hopefully that one works.
Perfect, it working now. A button to switch on/off the camera would now be perfect.
Oh, I’m so glad to hear that the change is having an effect! That way, those types of cameras can also just be viewed on the dashboard.
I’m going to take a look at how I should handle that, because it will naturally be tricky since I have different cameras than you do. But there are probably more people who want to use this option, and they might not have it at all or might have it in a different way. That would mean I’d have to add a lot of options for all kinds of different cameras.
A Control option is now also available on the camera details page.
Select Control to open the page with the configured buttons.
To do this, go to the Round Dashboard section on the settings page. Open the “Remote Access” tab. Make sure the checkbox is selected so that the “Create QR code” button appears.
Press the button. A pop-up containing a QR code will appear. You can scan this code with a phone or tablet.
A message will appear in the browser asking you to enter a name for the device.
As an additional security check, a verification code will be displayed on both the phone or tablet and in the pop-up on the settings page, ensuring that the correct browser is connected.
Select a profile and accept the connection.
Hi Dietrich,
Hopefully you can use this to turn your camera on/off
It’s working. Thank you.
