I’ve been working on an app that shows the dashboards you build in the Homey app in a web browser on your home network. I use it on a tablet on the wall; it should also work on a laptop or a TV.
Proof of concept. It works on my Homey and is available as a test version (test versions aren’t reviewed by Athom). It uses parts of the Homey Web API that aren’t documented (dashboards, moods and camera streams), so I’m not sure Athom will accept it for the regular App Store like this, and a firmware update could break it.
What it does
- Shows the dashboards you made in the Homey app and updates them live. You switch dashboards by tapping the name at the top.
- Supports the built-in widget types I know of: favorite and selected devices, Flows and moods; a zone’s devices, moods and lights; lights, speakers, thermostats, energy, Insights charts, sensors, zone controls, the timeline, batteries and low batteries, weather, variables, notes, camera snapshots and live cameras, web pages and dashboard shortcuts.
- Widgets from other apps work too. They run in a sandbox, so they can’t read the API key. A widget that needs to remember something can get storage and still stay sealed off, or you can trust it to run as it does in the Homey app.
- Edit mode: move and remove widgets, and change a widget’s settings like in the Homey app: its title, the devices, lights, Flows, moods, variables or dashboards it shows, a chart’s Insight and time span, a note’s colour, the timeline’s categories and an app widget’s own settings.
- Tapping a device opens its controls: on/off, dim, colour and white temperature, blinds, the thermostat dial and locks.
- Live camera video uses Homey’s built-in stream conversion.
- Flow cards (thanks to @Erikvl87): show a dashboard or highlight a widget large or full screen, on every screen or one named screen. The door camera when the bell rings, for example. Flows can also check and close a highlight, and react when it closes.
- Light and dark mode follow your device.
- Browsers don’t need their own API key. You save one key in the app’s settings, a new browser shows a code, and you approve it in the Homey app. The settings page also checks the key and lists permissions that are missing or broader than needed.
- There’s a kiosk mode for wall tablets: it stays on one dashboard, goes back to it after two minutes without a touch, and unlocking it needs an approval in the Homey app. On an iPad you can add it to the home screen to hide Safari’s address bar.
- Fit to screen width shrinks the dashboard until all its columns fit, instead of scrolling sideways.
- Open dashboards reload by themselves after the app is updated.
The page is served by the Homey itself, so there’s no separate server to run.
Limitations
- Needs a Homey Pro on firmware 13. I’ve only tested it on a Homey Pro (Early 2023) with 13.5.3. A Homey Self-Hosted Server should work too, but nobody has confirmed it yet. It doesn’t work with Homey Cloud.
- Only works on your home network (it uses the
*.homey.homeylocal.comaddress), no remote access. - Adding widgets and creating, renaming or deleting dashboards still happen in the Homey app. So do the settings of zone, camera, sensor, zone control and web page widgets, and a note’s text.
- Editing needs a key with the Dashboards permission (
homey.dashboard). A key without it shows the dashboards but can’t change them. - Some device controls are missing: mode pickers (fan speed, for example), buttons (like “open lock”), and the sensor, battery and media tabs.
- I couldn’t test the dynamic electricity prices widget because Athom still does not provide them for Austria…
- Web pages that don’t allow embedding (Google, for example) stay blank.
- All paired browsers share one API key. You can sign out a single browser on that browser; signing out all of them means replacing the key.
- Whether the screen stays on depends on the browser. On an iPad, set Auto-Lock to Never.
- English only.
Trying it
Test version: Web Dashboard | Homey
After installing, open the app’s settings in the Homey app, create the API key as described there and open the address it shows.
Source code and issues: GitHub - stefan-schweiger/dev.schweiger.dashboard: Homey app that shows your Homey dashboards in any browser on your home network · GitHub
If something breaks on your setup or a widget looks different from the Homey app, let me know here or open an issue. Side-by-side screenshots help.
