Here are some more screenshots…
Looks like a companion for Homey Portal
I took another look into that night mode. I already thought it was strange because it’s actually built-in. When you switch your phone to dark theme, the entire Homey app changes, as well as the Home Overview widget
I could add an option in the widget settings so you can choose. Automatic, dark, or light.
For the homey dashboard I prefere the dark mode but not for other apps. So I dont put the whole mobile into dark mode.
Some other widgets for homey have a setting for constant dark mode.
Home Overview v1.10.84 – New Local Dashboard ready for testing
A new test version of Home Overview (v1.10.84) is available!
In this version I’d especially like to get your feedback on the new Round Dashboard. ![]()
The dashboard is available through a local link, so you can open it in a browser on a device connected to the same local network as your Homey. This makes it especially useful as a dashboard on a tablet or other dedicated screen.
How to test it
1. Install/update to Home Overview v1.10.84 (test).
2. Open the Home Overview app settings.
3. Go to the Round Dashboard tab.
4. Configure the required Round Dashboard settings and choose what you want to show on the dashboard.
5. Save your Round Dashboard settings.
6. Use the local link shown there to open the dashboard.
You can drag and drop the icons on the main screen as you like. Press and hold until you can move it around.
The settings page is still a work in progress.
It will be cleaned up and improved in a future version. You do need to configure the options under the round Dashboard tab for the dashboard to work correctly, but for now I’m mainly interested in your experience with the dashboard itself.
Feedback, bugs and ideas are very welcome!
Hello Erikje,
Ihad a quick look at the new dashboard. It looks realy good. Well done.
It seems that the change from color to white mode within the light section is not working.
I will test intensive tomorrow.
I just pushed v1.10.150 to test. A tremendous amount of work went into it, mainly to roll out a new style across Energy, Lights, Climate, and Speakers in the Round Dashboard.
My plan for the next version is a complete overhaul of the settings page, allowing you to create multiple profiles and specify what can be seen and controlled in each on the Round Dashboard. As a result, you’ll get multiple local URLs, each with its own layout. This idea was actually sparked by my daughter—she wanted to be able to control some things too, and that’s how the idea came about.
The color white mode change now working.
I really like the idea of multiple different profiles. So I can create one for me and another one for my wife. She don’t have to have access to all devices ![]()
It’ll take a little more patience, but it’s coming soon ![]()
Version 1.11.1: Profiles for the Round Dashboard
Version 1.11.1 is available in the test environment as of today! This update makes it possible to create custom profiles for the Round Dashboard. For each profile, you can define exactly who is allowed to see and control each section.
What can you configure for each profile?
· Modules: Choose which dashboard modules are visible.
· Devices & Services: Define per category (lights, speakers, climate devices, scheduling, monitoring and modes) which devices are visible and whether they can be controlled.
· Permissions: Enable or disable multiple options in one action.
How to create a profile
1. Go to Round Dashboard on the app settings page.
2. Click + Profile.
3. General: Give the profile a clear name and an icon.
4. Dashboard: Select which modules should be available.
5. Categories (Lights, Climate, Speakers, etc.): Select which devices may be visible and whether they can be controlled.
6. Permissions: Optionally adjust general settings quickly.
7. Click “Save profiles”
8. Access: Generate a unique link. Open this link in a browser to go directly to the dashboard for that specific profile.
Quickly link via your Homey account
Do you want to link a device or browser directly to a specific profile? You can do this using the “Open Dashboard” button:
1. Press the “Open Dashboard” button. (Only visible when you are connected to the local network.)
2. Log in with your own Homey account (or the account of a housemate/guest who is linked to your Homey).
3. Go back to the settings page; a pop-up will now appear automatically.
4. Choose which profile you want to link to this browser/login and save it.
Below are the other Dashboard settings, such as:
I really hope you’ll enjoy the new features! Quite a lot of time, testing and research has gone into this update, and I’m very happy with how it has turned out. Most of all, I hope it adds something useful to your setup.
And naturally, I’m already thinking about what could come next. ![]()
One of the things I’m currently investigating is remote dashboard access outside your local network. This would mean that you could potentially connect to your dashboard even when you’re away from home and not connected to the same network.
I’m also considering registering a dedicated domain for this purpose and combining it with a Homey login, with the goal of making remote access both easy to use and as secure as possible.
There would be a small yearly cost involved. It’s nothing significant, but before putting more time and effort into developing and maintaining this feature, I’d really like to know whether this is something the community would actually use.
Hi Erikje,
first I want to say thank you for your exelent work.
I’ve just done a first quick test with the new version.
In the general configuration for the lights, I enabled three lights in one zone.
However, in the Dashboard settings, only two of them appear under the light settings. The same applies to the corresponding zone in the Dashboard itself.
The missing light is connected via a smart plug, which is defined as a connected device with the device type “light”.
Best regards,
Dietrich
Thank you so much for testing and letting me know! I will definitely take a look at it and do my best to resolve it.
I made an adjustment in version 1.11.2, and these devices should now also appear in the list
Ok, that’s ok now. But it would be more nice to see the divice names intead of 1, 2, 3 . So you know wich light you turn on.
I completely understand what you mean, but I haven’t really found a way to make that clearer because when the device name is shown underneath, it’s very small and long names are, well, long. By the way, if you long-press on a light device, it takes you to the device itself.
Hi Erikje, I understand you point.
I was not aware of the long press action, that makes it perfect.
Thank you.
Version 1.12.0 is now available as a test version
· I have added a new feature for the round Dashboard:
Under Profiles, you will now see an additional Cameras tab:
Just like with lights and speakers, you can specify which cameras should be visible and which ones can be controlled within that profile.
Next, open the round Dashboard. If Cameras is not displayed yet, press and hold an empty tile to open “Edit home screen.” You can then customize the screen by removing options or adding new ones using the “+” icon.
Press the “+” icon and select “Cameras,” which is available because cameras have been added in the profile settings.
Then tap it to add it.
Cameras will now appear on your home screen. When you open Cameras, you will see the cameras you selected for viewing and control. Tap a camera to view its live feed or refresh its snapshots.
