Hey Rik sorry for the late answer.
Yes this app can do both things that you want ![]()
I guess i can add a card to exchange address into gps. will check it soon.
Hey Menno,
Thx for the answer anyway! But i figured it out using Tasker (a whole new world is opening up!
) so now it works perfectly!
@Joris_Vandamme I have found a solution!
Thanks to martijnpoppen (God bless him and his work <3), we now have an Apple Find My Device integration that enables you to retrieve latitude and longitude directly via API.
Pay attention to one thing: I have initially created a flow with the card “When Longitude changes” but this field updates itself too quickly so I ran out of API calls to the HERE API XD
Just use the card “every x minutes”
@Luca_Lorenzi
Thank you for this information.
In the meantime, I have already tested this app, but unfortunately, there are some downsides, such as receiving a lot of emails stating that your Apple ID has been used. And the biggest downside is that it drains your battery very fast…
To mitigate this, you can use the set server interval flowcard. With this card, you can reduce the calls and, for example, turn it off at night.
I set this every 15min according to my flow. This will drain less battery
For the emails you can set a mailbox rule… but this could remove visibility to real unauthorized login. If I have a smarter solution I will write to you
Homey has Limited some cards to advanced flow only.
So i guess it’s a issue that they created in the app.
In case the flow is not starting while everything else is working, then macodroid doesn’t have access to your location. When you’ve set macodroid up for the first time, add a location trigger first to set the required access to your location. Remove the location trigger and then add the timer of every 15 minutes.
Good Evening,
I have a problem.
Api key became invailid and i can’t skip billing details.
Is this a known issue?
Hi Peter, thanks for your reply. I don’t plan on giving away my payment information either. Are you looking for another solution, or is there one already?
Hello Stijn, YW.
I’m not aware of anything similar, maybe the ETA Google Maps app, but this also requires providing billing info up front.
All location apps:
https://homey.app/en-nl/apps/browse/#filter?category=localization&platform=local
Since a couple of days I’m getting the following error message when I want to use information from the HERE app in my flow: AxiosError: Request failed with status code 400. Apparently this has something to do with the authorization. I check my API Key: it’s still valid, so that can’t be the problem. Is there anyone else who’s facing this issue?
