[APP][Pro] Harmony Hub (v2.0.7)
@Ranney Running into the same problem after finding the harmony hub during setup for devices i get a network timeout.
Found the issue related to v4.15.250 of the Harmony Hub firmware. Good news is that it seems fixable but it will take me some time (around 2 days) to provide a fix. Will keep you updated on this.
Is it caused by another change they made in the firmware? Regarding the API-access?
Yes, they deprecated an api call that this app was using. Have to refactor some parts to get around that and the app should work again.
Hi, any progress on the fix?
Thank you for taking care of this. TV is a big part of my automation here up in Norway :slight_smile:
In the Homey app I see all these red exclamation marks too, but luckily all my flows that rely on the hub work fine.
I only use ‘when activity x is started’, to blah blah blah. That still works for me.
Yes, while working on the fix I also detected that since the latest Logitech Harmony Hub firmware they changed the unique id of the hub. I have a version fully working now that would require a deletion of all devices and activities + a repair of those devices. At the moment I am looking into a way to prevent this, although this would take a bit longer for the fix to hit the store, I don’t want to confront everyone with having to re-do all their flows so I think its worth the wait.
I expect to publish a new version late tomorrow or early on the day after tomorrow. After that we need to wait for Athom’s approval.
Sorry for the inconvenience,
Jeroen
Thanks for all the work you’re putting into this.
You don’t need to apologize, Logitech is the o e that should stop messing around with the firmware!
Good job!
Strange. I dont have any problems at all
Probably your Logitech Harmony Hub isn’t updated yet to the newest firmware (v4.15.250).
@jreenen Just wanted to say that your knowledge and programming skills makes our homes so much more greater than it was before! A big thank you for always holdning us up to date with info and also for all the time you spend with this!
+1
I am currently testing the version that is available for CLI install on https://github.com/jreenen/com.jreenen.homeyharmonyhub/tree/fix/latest_hub_firmware
Currently there is one known issue: if you pull the plug from your hub the app doesn’t detect it. I want to fix it but I might publish this version with the known issue if I can’t fix it today.
Looks all good Jeroen, things are back up and running.
I did have to re-add cards to my flows, not sure if this is because I had already uninstalled / reinstalled. Many thanks!
Published version v2.0.2 for the app, it’s up to Athom to approve it, after that the store version will be updated. There is 1 known issue: The app doesn’t detect it when the plug is pulled from the hub, will get fixed in an upcoming version.
@Jan_Hilhorst your issue " Homey flow is triggered AFTER the Harmony activity" should be fixed also in this version.
Tnx. And tnx for sticking so much of your time in this.
If you uninstall the app indeed all flows must be recreated after re-installing.
The app is updated to v2.0.2 this should fix the issues on the Logitech Harmony Hub firmware v4.15.250.
Also @Jan_Hilhorst your issue " Homey flow is triggered AFTER the Harmony activity" should be fixed also in this version.
And I have good hope https://github.com/jreenen/com.jreenen.homeyharmonyhub/issues/47 is also fixed in this release.
