[APP][Pro] Eufy Security
Can you send me another report?
I’ll double check the settings.
Here we go
32fdb082-7dc7-47c0-9d03-56deff1ed628
Yeah all seems good except the timeouts.
Homey cannot connect to the camera somehow.
Only thing I can think of right now is to verify if Homey can reach those IP’s.
You could try netscan and see if Homey can find the IP
As far as I can tell from the logs. The cameras are not in the same network. :confused:
Hi there. Definitely the Cams and Homey are in the same Network. Checked again. Everything is running smoothly with the Indoor Cams. Only the Solocams are not working. Homey is receiving all the values like last movement detection, temperature and battery status.
Hey,
The indoor cams are. Those are responding.
The Solocams are giving timeouts.
There’s nothing I can do from my end except telling that Homey can’t reach these ip’s:
192.168.1.58 / 192.168.1.152 / 192.168.1.188
The events are going via a different protocol and don’t need a internal connection. To control the camera you need a internal connection from Homey to each individual Solocam
It was definitely working last week after the 1st installation. Got my Homey before Christmas. The problems with the Solo Cams I have since the update of the app. This is the obly thing I can tell you. How I can proceed a Netscan? I‘m still new in the Homey world.
Hey
Send you a DM
Let’s check what we can do :slight_smile:
Hi @martijnpoppen
I replaced my doorbell with the Eufy wired 2k doorbell. The thing that doesn’t seem to work is turning the camera back on. From Homey turning the doorbell off (when we are outside) works. But turning it back on doesn’t seem to work.
The IP in the app settings is correct. This works fine for my 2 eufy battery cam’s through the homebase. Though not for the doorbell
Is this a known issue?
Hey @Stefan_Lenders
No not a known issue
Can you do the following:
  • turn doorbell off
  • turn doorbell on
  • send me a diagnostic report
More - apps - Eufy Security - settings wheel right top - send diagnostic report
Sent: ffc87240-db94-4ec6-92f0-4a23333d927f
@Stefan_Lenders I don’t see any issues. Also the commands are sent properly.
Can you describe what goes wrong?
Or make a screencast or something :slight_smile:
Hi martijn, i Made a flow for the Flood light : Shared Flow | Homey
Bud in the eufy a it stays on home.
Can you take a look?
dd92e3fc-2cdf-4d96-8b6e-9c5df74168d9
The ip adres is local. But i Sint know of it is changt
Hey @Yannick_Eeckelaert
Best to check in the app settings if the IP is a local IP
Local op adres is ok, i toggle the light
Make sure to refresh the official Eufy app. Because the change is niet visible directly
Edit: you can also send me a report if you want
@Yannick_Eeckelaert theres a strange error. I would suggest to restart the app
Just restart the app nothing jet. Witch error?
Wil cheque when i am home. With the home base it works fine.
Met vriendelijke groet,
Yannick Eeckelaert
Strange that Evvery Ting works fine buth the Security status.
Yannick Eeckelaert
I don’t see anything strange.
Do the other Security modes work?
No non work, i wil try to delete the device en reinstall. IP adres is good. En fixed in modem.
Yannick Eeckelaert
