[APP][Pro] Eufy Security
862459a6-f477-4a69-a456-995e8b7b63ad
Ha. Problem was at my side. I unplugged the chime to check if there was indeed a sd card in it, then plug it back in. After that it has gotten a different IP adres.
I update the Eufy App accordingly an now it seems to work!
Let me test it a bit more, will get back to you later
@Frank_van_de_Schuur That was the same conclusion I just had :stuck_out_tongue:
You can try to fix the IP in your router so i won’t change any more
Yes indeed. Didn’t get to that yet.
Looks good so far. Thanks
@Frank_van_de_Schuur does the chime also have alarm settings? The Homebase 2 has those. So might be good to check if that’s the same for the Homebase-Chime :slight_smile:
Homebase 2 settings:
Yep. It does.
Nice! so it does act like a Homebase :smiley:
I expect you can add other camera’s to it if you want. Like the Eufycam 2 and even the Keypad
New app update (live: 2.14.0):
Changes:
  • NEW: add Homebase-Chime for Battery Doorbell Slim
@Frank_van_de_Schuur you can install the live version if you don’t want to receive test updates anymore. Click the above link to install that one :slight_smile:
Hey all,
Saw a lot of comments about a delayed stream url.
To speed up the stream you can do the following: (also added to the FAQ)
To Prevent delays: Make sure to set your Stream to Smart Display first. you can find this when you go to you camera settings → video quality → Streaming to Smart Display
Tnx. Will do so
New app update (test: 2.15.0):
Changes:
  • NEW: add Solocam Series E20/E40
  • NEW: add Solocam Series L20/L40
  • NEW: add Solocam Series S40
@Arjo_de_Bruin Can you check if this works for you? :slight_smile:
Hoi Martijn,
Ik heb je ‘test’ versie geïnstalleerd. Maar hij vindt geen camera… de solo zit niet gekoppeld aan de homebase maar heeft een eigen IP. Ik denk vergelijkbaar met de deurbel?
Met vriendelijke groet,
Arjo de Bruin
Hoi Martijn,
Hierbij wat gevraagde screenshots:
Arjo de Bruin
New app update (test: 2.16.0):
Changelog:
  • NEW: Flowcards text for Webapp
  • CLEANUP: Merge 1080P and 2K doorbells together in 1 device.
  • FIX: Change device type of doorbell from camera to doorbell
Hey @Arjo_de_Bruin ,
Thanks for sharing.
Make sure to keep this part of the forum in English, so everybody can read along.
Did you share the camera with you extra account?
Hey Martijn,
No I didn’t. Just figured that out and I managed to add the solocam to the Homey (eufy app)
I looks like it works like a charm.
Thanks for the quick adjustments!
I keep you posted on flows I will adjust later on.
Cheers,
Arjo
@Arjo_de_Bruin Awesome! Yes let me know if everything works as expected.
These camera’s are a bit of a combination of the new outdoor cams together with the Eufycam 2 :stuck_out_tongue:
New app update (live: 2.16.0):
Changelog:
Just a question. Is the HomeBase (2) always needed or could you connect the following product to Homey as well? And if so are there any disadvantages using this product?
Hey @MarcoG,
That one is the same as the Battery doorbell 2k. Except it uses a Chime as a Homebase.
Functionality is the same.
Eufy is moving away from the Homebase it seems and moving to these chimes.
Disadvantage is wifi-only i think
