[APP][Pro] Eufy Security
Thats a quick response :+1:t2::+1:t2::+1:t2:
92fdc058-cc5a-45fd-90b9-0d9f5c46d566
New app update (live: 2.13.5):
Changes:
  • FIX: pairing - add T8020 to 1080P powered doorbell.
@Frank_van_de_Schuur the device id was missing in the pairing list. Added it now.
When you click the link above you can re-install the app and try it out. :+1:
Wow!! Wow! Wow! You are the best.
I’m really impressed how quick you responded and solved it!
It works fine now, I’ll go and create some flows tomorrow.
Can i donate somewhere somehow to express my thanks?
No problem! :smiley:
Yes in the top post of this forum you can find a paypal and/or Ko-fi link
Done
Thanks a lot! :smiley:
@heula
So again I did some investigation on the following:
  • [Feature Request] alarm delay (beeping sound) before alarm goes off
  • [Feature Request] Fix restart Homebase flowcard
But it seems like i’m unable to fix this. I tried a lot of different things. But not possible. I do expect the 2nd point will be possible in the future. But the alarm beeping is something which is hidden somewhere inside the flow logic of Eufy. : (
Thanks for trying Martijn. I have already replaced my aqara frontdoor sensor with an Eufy door sensor so that fixed the beeping sound for me.
About restarting the homebase, I do that very little so if needed J do that from within the Eufy app.
Keep up the good work.:+1:t2:
@martijnpoppen would it be possible to add the feature to turn on/off motion detection via homey?
I would like to use it in the following way: when any family member is at home then a notification/trigger is only needed on button press, (ringing the bell)
However when nobody is at home then I also want to be notified of motion near my front door.
Hey @Frank_van_de_Schuur
Yes that’s possible.
What I would do:
In the official Eufy app
  • create 2 Security modes. (home & away)
  • for home you disable push notifications
  • for away you enable push notifications
In Homey:
Perfect idea indeed. except…it seems that this card is not available in my situation:
You can find that card in the Homebase :slight_smile:
Don’t have a homebase. Just the wireless battery powered doorbell and a chime.
I could use the geofencing in the official Eufy App but then this only works with me personally being home or away
Can you send me a report maybe?
Then i’ll have a look. Might be that this is not supported.
You can do that via:
More - apps - Eufy Security - settings wheel right top - send diagnostic report
d28e2284-cf95-46fd-9089-767dcea306da
Here you go
Thanks, i’ll come back on this tomorrow.
But i think it should be a separate device as it’s different from the exisiting devices
This is the new doorbell.
So for my understanding: it’s a battery doorbell without Homebase but with a chime?.
(So actually like a combination of the old doorbells :wink: )
Correct!
New app update (test: 2.14.0):
Changes:
  • NEW: add Homebase-Chime for Battery Doorbell Slim
@Frank_van_de_Schuur I added the Homebase-Chime to the devices. If you add this one you’ll have the change security mode flowcard for this device.
Can you give it a try and let me know?
Make sure to click the above link and install the test version
Have installed the test version and was able to add the homebase chime device.
In the device i can see that i can change the security mode.
So I created a ‘test flow ‘ to test changing the security mode but it does not seem to work.
In the flow card that changes the security mode i get this rotating circle that the action is pending.
Can you share a report? :slight_smile:
