Reason enough to text your neighbor for an emergency request, right?
No there’s not an public API. This is based on An reversed engineered library. So for now only able to do what the library has to offer.
They’re also discussing this on the home assistant forum: Eufy Camera Integration - Feature Requests - Home Assistant Community
Hello, trank for the app. I managed tout set my camera eufycam 2 but my indoor cam and my indoor cam pan-tilt, for the two, security setting don‘t work.
Where ist the extra Setting (this will increase the Performance of this app …?)
What is my probem?
Sorry for my english i‘m a poor french:)
Hi @David_Ogo ,
That setting is removed as of version 1.5
I made it default enabled, because everybody wants to use it.
If you want you can send an diagnostic report. Then I can take a look. Or send me your ACTOR_ID and enable debug in the app settings
Also good to check your Homey version. This version only works with version v4.2.0 or higher as this has NodeJS 12 which it needs.
@martijnpoppen Just donated you a couple of drinks for the great app and support!
Hope you can enjoy them soon once the lockdown is over.
Cheers!
Thanks a lot @MrBlue
It works perfectly! 10/10 for the support, thank you! I had to set up 3 sec delay to the flow as the notification on TV is a bit slow, however it works like magic!
Normaly i send you the report with number 8eaba7ed-c792-40dd-8899-3cb134d518c1 and debug ist enable in the app.
My homey Version is v4.2.0.
Thanks
Sent you DM
Martijn you did it!! Great work!! Pan/tilt on/off with geofencing… GREAT!! Thnx
There’s an issue when people have multiple devices and use the on/off or security mode it selects the wrong device. I’m working on a fix for that: [BUG] - multiple devices are turning of wrong device - check index · Issue #18 · martijnpoppen/com.eufylife.security · GitHub
Thanks for this great addition to homey @martijnpoppen !
im using the 1.6.3 version of the app with homey FW V5.0-rc53.
After the last update i’ve repaired my Indoor cam (fixed version). but i dont get the pictures (on the device or in the notifications). is this not possible with this model (did i miss this somewhere)?
Thanks in advance
I’m unable to cast a pic in a flow. I have several EufyCam 2 around my house. In the flow I choose when a person is detected as the trigger. I have 1.6.3 and Homey 5 rc 53.
Am I doing something wrong?
Thx a lot!
//O
Hey @matrover ,
Can you enable Debug inside the appsettings and send me your ACTOR_ID in a DM?
Did you include the image tag (pink tag) inside your flow?
Like this:
Hey @Oscar_Strom ,
EufyCam2 handles notifications different so might be good to check that.
Thnx! Done that.
Thnx @martijnpoppen after a restart of the app (as you suggested) and readding the device it works!
Donated a few beers for this awesome app and support!
Thanks a lot @matrover !
I got it working in combination with my 2k doorbell.
I had to set some special permissions on my Android tv
I tested with this flow and got a picture of the doorbell:
