[APP][Pro] Eufy Security
Can you tell me where you exacly find it in Android TV OS? English menu please :slight_smile:
I just googled it but it should be something like this
Thank you!
Does anyone know if it’s possible to pip from homey to a 2 year old Samsung? I guess Samsung has made it difficult for others to interact with their platform. Every one should use Smartthings in their opinion.
//Oscar
Hey all,
Added a new update to test. (v1.7.1)
This update fixes the issues for on/off with multiple devices.
What were the problems:
  • on/off turns on/off wrong device instead of selected device
  • on/off inverted for almost all devices except indoor cams
This probably will fix it for you: @OetAelse @David_Ogo
Hi Martijn, will test today and share the result.
The Update has Not yet been done, i ‘ll keep you informed
Does it run on AndroidTV OS, then yes.
If it’s their own OS, then likely not.
Again a new update in test:
v1.8.1
This time added events to the devices so you see the same events as in the Eufy App:
How can i do the update ?
You can install the latest test version from this page: Eufy Security App voor Homey | Homey
On 1.8.1 I see the picture from my Eufy doorbell in the Homey app. Sending true Telegram stopped working. Was working for 1.7.1
Edit: never mind. Restarting the app fixed it
Camera state on/off state is fixed however my doorbell and eufyCam 2 are still switched around even in version 1.8.1
My doorbell (2k battery) is working fine.
@OetAelse Hmm, i’ll check your logs. You have the DEBUG still enabled?
Mine too, let me explain. I have a doorbell and Eufycam2 connected to Homebase 2 and 1 Eufy pan & tilt camera. When I add a new device in Homey I get a list of all 3 Eufy devices, selecting the doorbell actually controls the Eufycam 2 and vice versa.
Martijn already knows about this.
@MrBlue Yes this is mainly when you have multiple devices and try to turn them on/off or set the security/guard-mode
Now it’s enabled Martijn.
Thanks will reach out to you via DM :slight_smile:
When I try to connect the Eufy doorbell 2K I get the (error) message “Something went wrong”
I’m running Homey 5.0.0-rc.57. I tried this with the released Eufy app And the experimental Eufy app
Does anyone have an idea?
[Edit] Found the problem, wasn’t logged in :joy:
