New app update (live: 2.11.4):
Changes:
- FIX: prevent invalid arm mode for Homebase
CC: @Felho
@Felho No idea where it went wrong. but it seems like Homey and Eufy got stuck in a loop together. This should fix it.
You might need to seed the correct arm mode in Eufy or in Homey.
I follow this thread for some time now and must say, it’s unbelievable how fast you fix a bug.
Last time you helped me in no time with a Robovac in the Home category.
Therefore hands up for @martijnpoppen
Come on guys, I hope many more will follow.
Thanks a lot @Hermann_Stengel !
Really appreciated
Also many thanks to you @Felho !
me thanks your always fast work…
Will it be possible to get snapshots to Homey when motions has triggered a cam 2? Think it is already possible for doorbell cameras?
Hey @Peter_Stark ,
Yes that works for every camera.
Make sure notifications are enabled and also the Security mode is enabled for notifications.
See FAQ Q1
[APP] Eufy Security - #4 by martijnpoppen
Hi @martijnpoppen ,
Most likely you already noticed the comment in the other thread, but taking the conversation here to keep the community organized
I realize that the Eufy security panel already works with the app and Homey, but this thread got me curious.
Would there be any chance that you could look into the Heimdall API so the panel could work with Heimdall on a more advanced level?
This would open up for user managed and 2-way communication to the panel which looks pretty cool.
Looking forward to your first thoughts.
But I do have to create a flow to get a push notification from Homey app in My Ios device? I see that the picture got updated when i look into the device in Homey, but i wonder how i can get a push with the picture from the camera:)
Great App!
@Peter_Stark Thanks ![]()
Yes like this Shared Flow | Homey
That is what i looked for before I wrote here, but the cameras does not show up in list of devices to get the picture from. Maybe Homey need a reboot?
You might want to restart the app first. That should registrer the images again
Hey @MrBlue ,
Thanks for your message.
I read the API docs and it looks really nice.
However there’s one issue.
From Homey we cant control the Eufy Keypad. We can only see that the keypad changed a Security mode and maybe we can see who did it.
So integration with Heimdall seems a bit too much. Currently you can change the Security mode of Heimdall once the Eufy Security mode changed trough the Homebase or Keypad
I think the Ring keypad does have the control from Homey and a therefore you can have a full integration.
If you have any different thoughts let me know
Thanks for looking into it!
Currently I don’t (yet) own a Eufy panel, but a fairly ‘dumb’ panel with a Fibaro Smart Implant connected, so I can’t really tell whether more would be possible with Eufy.
The user mgmt capabilities still sound quite nice though (missing that in my current setup) l, and would really make me consider purchasing a Eufy panel.
@MrBlue
Yeah I’m thinking now if I can extract the name of the user from the notification.
I think that’s possible and would even work when you change modes with the app.
Then you could have a token in your flow to check the name.
I was thinking of buying a Eufy Keypad, but didn’t see the advantage
I use smart presence and based on that I know who is Home or not. To override it I have a aqara button which you need to press in a sequence and that will disable the alarm.
@martijnpoppen @MrBlue the Ring Keypad is indeed directly connected (through Z-Wave) to Homey and controlable in the same way as it would be when connected to the Ring Alarm system. I haven’t read the whole post but I guess the Eufy panel isn’t connected directly to Homey but via a hub, am I correct? If so, I wonder what technologie is used for the connection between the hub and the panel?
@DaneedeKruyff Yes that’s correct. In case of the keypad I’m not sure. I guess it’s a P2P connection. The same as for all the camera’s.
The keypad doesn’t have any commands I can send to it.
Eufy works in a way that when a notification is send. Homey intercepts that and acts on it.
So in case of the keypad the Eufy Hub sends a notification like Security Mode change to Away. In Homey the security mode will be changed at that point.
So there’s no way to control the keypad.
I think with the current functionality it’s already possible to connect with Heimdall, but it’s not that nice as the Ring keypad.
Something like this: Gedeelde Flow | Homey (sorry I don’t use Heimdall
