[APP][Pro] Eufy Security
@Graaf I see
Will check if this can be changed
@Graaf I checked but not possible to disable that without interfering with users who do use the RTSP stream. As for now there’s no way to set the preffered screen, I did request that at Athom a while ago
Thank you for looking into it.
I am planning to move my very basic Aqara alarm system on to Homey but came across the problem of integrating an outdoor siren into the system. I don’t have power or USB to the front of the building but I thought I had found the perfect solution. The Eufy Security Siren. It is battery powered, needs the Eufy Homebase 3 which I already need for their cameras, it can cope with being in a sheltered place outside and it would mean I didn’t have to introduce another protocol.
However I have heard that it won’t integrate properly with Homey.
Has anyone any experience of using the siren and managed to get it working?
Thank you. Gareth
Hi Gareth. I don’t think this can be done at the moment. The best app is the Eufy Security app by @martijnpoppen which covers a huge amount of Eufys stuff - sadly not the siren
I am no expert but i believe it cant be added yet sorry. perhaps Martijn can be more technical
The HomeBase works with Homey. If you add the siren to the Eufy app it will make noise once the alarm is triggered. I let Homey switch between my modes. So not really needed to add it to Homey.
@Gareth_Roberts see [APP][Pro] Eufy Security - #5 by martijnpoppen - Apps - Homey Community Forum
saw that E42 is currently not supported. i have two of them at home, is there anything i could help you with. happy to help.
regards,
@Trimix check [APP][Pro] Eufy Security - #5 by martijnpoppen - Apps - Homey Community Forum
(post deleted by author)
Hey is there a chance or manual to connect the c37 cam?
@Dima-g see [APP][Pro] Eufy Security - #5 by martijnpoppen
I setting up a new Homey Pro and am trying to connect an Eufy 4G LTE CAM S330 camera with little success. Is this model compatible with Homey Pro. (I am using the 2nd admin account to login).
@Flu67 check [APP][Pro] Eufy Security - #5 by martijnpoppen - Apps - Homey Community Forum
Hi Martijn,
I’m still experiencing daily crash on snapshots even with hours of delay between. I’ll not use this feature anymore because it breaks my flows for a minute every time this happens.
@Vincent_Roue the snapshot function is really memory heavy and is still a experimental feature
There’s no guarantee it works properly and can’t be optimised any further
Conclusion: this is what it is
I was able to add my camera, but everytime I try to make a setting in the homey app I receive the error message “Property name is not valid”
Camera C220 without Base
5f75c393-e138-4dd3-b6cd-7883c984a0d4
@AlxFlk known issue and no fix yet
This thread already mentions that many times (search function)
The app doesn’t find my homebase 3. Only once I managed to get to login credentials but then the homey mobile app just said:
SQLITE_FULL: database or disk is full
@martijnpoppen Please add the new eufy HomeBase™ Professional S1.
Thanks really appreciate your work on this app!
