Ok, Thanks for the info can I use the minibase Chime or need I use the homebase 2 or 3
@benito_stijger, yes that should work!
hi I am after some advice regarding snapshots.
my flow
when my camera E340 floodlight, or my C120 indoor cameras detects a person, then creates a snapshot.
then 20 sec delay push the snapshot to my phone.
the snapshot that is sent to my phone doesn’t capture the person/ event, like its taken after the event, in clear full screen view.
if I use event snap shot instead of the device snapshot it gets the event, but its in a split screen view that’s too small see any detail.
Ideally I want a full screen view snapshot of the actual event,
is it possible, what do I need to do
Hi @Ronwell
As far as I know this is not possible
Can you try and add the E10 Smoke detector?
Great app by the way
Thanks a lot for this app. However, it keeps locking up my homey and reboots. Only connected device is a homebase s3, all flows disabled. Any info you need from me to check this possible issue? Report: ee3d1487-37ee-4ca8-9781-9c22697354b1
Thanks a bunch.
@Erik_Dahl Unfortunately i can’t see anything related to that in the log. When you disable the Eufy app the reboot of Homey stops?
That is correct, and unit becomes unresponsive. I’m happy to help if I can help out with anything. I’ve tried to create logs through simple syslog but it’s not producing anything. Guidance is well appreciated.
@Erik_Dahl I can’t really help with this. There’s no information in the logs so I can’t tell you what to do
Please try to create a report when the issue occurs again
Thanks for letting me know. You have any good ideas re howto create meaningful logs? Sems like simplelog wont cut the line.
Thanks,
Just FYI, it seems like your app was not the issue. The issue was right here behind the keyb ![]()
@Erik_Dahl thanks for letting me know!
@martijnpopppen Would it be possible to add an device setting to disable the live RTSP stream feature? I don’t use this functionality, and when I tap a camera device card in the app, it shows in the ‘black screen’ the attempt of loading the live stream as default. I’d prefer to see the snapshot as the first view instead.
@Graaf yes by disabling it in the eufy app on your phone
I didn’t enabled RTSP in the Eufy app, but it still shows it in Homey with the error: player is unabled to open the MRL ‘RTSP_not_enabled_in_EUFY_app’. Am I doing something wrong?
@Graaf if you restart the app it will be gone
I tried restarting the Homey app multiple times, but it’s still there.
@Graaf please send a diagnostic report
Done! Thanks for your help and time.
a64357b6-f90e-4479-8d5d-9d90e7f46542
