[APP][Pro] Eufy Security
oh im sorry, here : ca1f03a4-7a51-4ed9-b0c8-b131204e1587
Yes, can confirm. Had to verify the part about resetting the alarm when motion triggers the alarm again. Found out that’s the case here as well.
@Eivind_Berntsen please see: [APP][Pro] Eufy Security - #5 by martijnpoppen
The camera you were trying to add was a Solocam E40, that’s a different model ( Eufy logic..)
New app update (:green_square: LIVE: 3.41.3):
Changelog:
NEW:
1: None
FIXES:
1: FIX: false positive motion alarm
2: FIX: snapshot misses
:collision: If you find any issues, send a diagnostic report
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - Eufy Security - settings wheel right top - send diagnostic report (add your email to the description)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select Eufy Security - Click on send diagnostic report (add your email to the description)
You can install this version by clicking the link (version number) above and press install
:fast_reverse_button: Don’t want to be part of a test version? Install the live version → Eufy Security | Homey
Looking for new device support? See [APP][Pro] Eufy Security - #5 by martijnpoppen
Trying to install 3.41.3. I can see the app on my homey but when restarting the app it says that the app is not installed and I cannot add devices.
Update: Just found the answer Homey Status
Unfortunately, seems like the Eufy app is one of the apps involved:
“ Upon further investigation, the issues with app installations and auto-updates appear to be limited to a few specific apps, rather than affecting all apps as initially reported.”
I experience the same: new test version of the app installed, but every device show a red exclamation mark. The app can’t be restarted, “Not installed” is the error message.
I seam to have gotten some odd behavior with camera RTSP lagging like nuts with the last version. (3.41.3) It is like showing every other xxx frame with a second or 2 between.
@Roger_Gorissen probably because it got recently updated. I asked Athom if a new release would help in this matter.
@Teddy nothing changed for RTSP. Do you see the same behaviour in a regular media player (e.g. VLC?)
Just made a new release of the app and that should fix the installation issue. Also informed Athom about it :slight_smile:
No vlc and eufy’s own app flow without issues.
I created a virtual cam based on athoms own driver and that does the same behavior as inside the app. Going to test restarting my homey.
@Teddy might be the webrtc proxy Athom recently introduced
App crashed. I get this message when restarting it:
@Roger_Gorissen I forwarded your message to Athom.
Reinstalled… everything works fine :grin:. Incidental hick-up.
Hope the wrong motion messages stay away with this version. That’s why you released it. Keep you informed.
Hi i got this on my S220 what could be the problem? @martijnpoppen
Could be..
@martijnpoppen , it looks like your update solved my issues.
The whole family thanks you, Martijn! :grinning_face:
@Thomas_Knudsen did you check FAQ Q14? [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum
