[APP][Pro] Eufy Security
Thanks Martijn,
HP19 - I think do not support Live stream, even with the RTSP activated, no option for Live stream
SHS - Live stream only with activated RTSP
the settings are like in the description, still no Event in SHS.
Can you please send me some doc./link about FFMPEG on mini PC.
RTSP i have seen that HA is using some WEBRTC/go2RTC - seems to work also with Homey for Live stream from battery cameras without RTSP.
Do you think it is possible to get Live from these Cameras in Homey?
@Chris_Barton the turned off is default when a camera gets added installed etc.
I will check the error. can you share a diagnotisc report?
@Viorel
HP19. Oh yes correct.. :man_facepalming:
SHS:
  • Event: can you share a diagnostic report after a event? (make sure to trigger some motion before sending the report)
  • FFMPEG: yes download and install here: Download FFmpeg
RTSP: yes that’s correct, however that still requires HA/Homey to start the stream, and that’s just the issue, it’s so heavy that it crashes the app. I already had this working but it can’t keep the stream alive because the app crashes. Don’t think this will ever work on Homey due to the limitations on the memory.
I’m however looking into other ways as the Eufy app seems to have new API’s but no guarantees that will ever work
You are the greatest.
I will be late at home this evening, i will make the Report, probably tomorrow morning.
Thanks
Hi Martin,
Please find below:
hope that helps
a6e944cd-3c5d-4f88-b808-179a6e5244f2
Here the Raport.
Just after Ringing the Doorbell shos Event Image.
Te ather ones by action event not.
@Viorel I do see that the event came in properly
Keep in mind that a doorbell ring doesn’t always contain a image (FAQ Q3) [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum
So for what I can see there’s nothing “wrong”
Hi Martijn
Please see below
e6460d63-7957-4dc4-a23a-ba0f67babac7
Cheers
Chris
@Chris_Barton thanks will investigate the issue, will come back on that
Thanks @martijnpoppen much appreciated!
Hy Martijn,
Regarding Event after activating the push Messages, the event Image is running, even with deactivated push Notification, still running.
Snapshots, even after installing the FFMPEG are not working.
Here also a diagnostic:
9ce996cd-3dfb-4165-8aa5-fd9001529720
@Viorel Oh that’s actually good news :slight_smile:
About FFMPEG, I’ll check, I have to admit you’re the first person I saw who had this issue, which make sense due to the short period SHS is live.
I’ll check and maybe try to reproduce myself. Your mini PC is a windows right?
Yes, windows 11
Thanks Martijn
Settings are correct. Both devices have notifications enabled.
Hey @martijnpoppen , I’m already using your app for a long time now and I am very happy with it.
I have not added any new camera’s for a while…, but I’m noticing that the memory usage of your app is growing alot over time.
Not sure if you have seen that yourself, but in my case it’s using 98.84 MB already. ( number 1 in the total of 41 other than system processes)
Now my question is are you working on optimising memory usage or something ?
@MRK please change the modes and then send a report
@Rens_Hoekema no I’m not. There’s nothing to optimise anymore. Not within my power at least
The SDK is quite heavy and all P2P connections of the cameras are really heavy
This is what it is
Until eufy provides a proper API one day
And somehow it’s working now. Will keep a look on it and will send a report when it happens again!
I have installed the eufy doorbell C30 and everything works fine in Homey. I can see the notifications, but there is one thing that isn’t working: the live view/preview. Is there any way to change this? Also, if I create a flow: ‘Motion detected → Take a photo → Send notification with photo,’ it doesn’t work—no photo is sent from the doorbell.
Hi @Damian_Surma
Please check FAQ Q17 for live video
And FAQ Q3 and Q14 for images
FAQ: [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum
