I think within 5min
Same for me
Hi and Thank you for your quick response.
I tried to delete my secondary admin account, removed all my cameras from my main account, added them again, made an new secondary account, and shared the cameras from the main account.
Uninstall the Homey app, reinstalled and added everything. Only one Camere shows live stream.
And the camera that is name “Carport”, is the one how isn’t working
Also noted that it doesn’t share snapshot eather.
When I hit the on/off button in the Homey app, I get “Property name is not valid”
I tried to repair the “Carport” camera from the Homey app, and didn’t get any errors.
Best regards
Glenn.
@b1ue3AGLE that was not needed at all.
Only needed to know if the carport camera was culprit.
I will check if I can find something
@Linden85 nothing in the report. It’s not possible for me to debug this as I can’t see the connection between camera and Homey.
I asked Athom, this is a bit out of my hands.
Hi, same problem!
Occurs after a few minutes of sometimes instant after opening the Homey app.
Hoping Athom has an answer!
Martijn; thanks for the updates and hard work!
@Andy_Henderson strange the SDK is the same for 3.37 and 3.38.3
@linden85 @Lukasz_Kostek @Jan-Marten
Questions:
when you open the stream in VLC or any other video player, does that run longer than 5 minutes?
can you give me the version number of the Homey app on your phone
can you tell me which phone you are using Android/Ios
you phone’s OS version
can you generate a Homey diagnostic report (not for this app, but full homey) and send me the code? (then i can share that with Athom)
-streams also stopped with vlc player
-running on 9.6.2 (1830)
-Ios version 26.0.1 running on 16pro Max
- diagnostic rapport : D9F0BED7
@Linden85 ok but then we can assume the issue is Eufy related and is not a Homey issue.
@Linden85 can you try to change the authentication of the RTSP from Digest to Basic in the RTSP settings of the camera? And then try again in VLC. It seems like that should fix it
no result unfortunately after about 5 min the stream stopped .(in vlc)
error message in Homey : video beëindigd
@Linden85 Not sure but this is out of my hands. I would encourage you to pick this up with Eufy support as this seems a hardware/software issue on their side
Edit: Eufy support, not Homey. Sorry ![]()
App version 9.6.2
Oneplus 13
Pozdrawiam
Łukasz Kostrzewa
śr., 15 paź 2025, 10:02 użytkownik Martijn Poppen via Homey Community Forum <notifications@athom.discoursemail.com> napisał:
Thank you ![]()
It’s the “Carport” how is the culprit. It works i VLC, but not in Homey app.
I’ve been searching and saw lots of complaints about this specific issue. Looks like this is a problem sinds 2023/24. People created workarounds by restarting the rtsp stream every 5 minutes. Doesnt look like Eufy is providing a fix for this issue…
@Jan-Marten Yep saw that too. But not really a sustainable solution
Hello guys,
I’m currently looking into replacing my security camera’s (which require a cloud subscription) by others. Eufy is one of the candidates, but from reading up here about the Homey integration and especially the future of it, I’m doubting.
Would you guys still recommend investing in Eufy, or rather look for another vendor? The integration with Homey is for me quite important.
Thanks,
