[APP][Pro] Eufy Security
@Ricardo_Aguilar no still there but works for some people and doesn’t work for some people
See [APP][Pro] Eufy Security - #5 by martijnpoppen - Apps - Homey Community Forum
@Brane_Brodnik the list with countries is from eufy its self. Which country did you use for the eufy app on your phone?
Please send a diagnostic report
@M_J to make that second flow work you shouldn’t connect the AND cards but draw 2 lines from person detected to the AND cards :slight_smile:
New app update (:green_square: LIVE: 3.36.2):
Changelog:
NEW:
1: none
FIXES:
1: FIX: add more countries to dropdown in pairing view
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Brane_Brodnik a lot of countries were missing, added them, see update above :slight_smile:
Thanks for the example. But this isn’t what i’m looking for. In your example the flow gives a notification for one of the two known persons.
What i’m looking for is a flow that gives me a notification if there is a unknown person detected. Like this below. But for a reason this didn’t work.
Maybe i’m not looking enough, but i can’t find a unknown person flow card in homey.
And if you turn the flow around? Click on the card with the right mouse button “bekende persoon is” Omkeren and then the card says “bekende persoon is niet” and then go with the blue line to the rest of the flow.
Checked indeed of this worked, but unfortunately also no succes. Strange thing is that the problems started when the flow need to check two persons. 1 person works without any problems.
For now you maybe use two cards “persoon is gedetecteerd”.
So two flows.
Like this below? Tested it, but also didn’t work :sad_but_relieved_face:
You use the block all, then you must have 2 thinks together, You must use the block any.
The block ‘all’ is also my intention. I’ll try to explain.
The notification card on the end with test may not be triggered if Michael or Isabelle is detected by the camera.
Maybe I don’t understand it properly, but as I see it now:
Suppose Isabelle walks through the camera. Then the top flow will be activated with any. And that is not the intention, because i don’t want a notification by both of the persons. With the ‘all’ card, both of the persons are blocked right?
@M_J I checked the code, but currently it compares the known person to the last known person, so even if there’s a unkown person it still validates against the last known person.
will try a fix for that
in the meantime you could use logic to fix it until my fix is ready:
Hello Martin,
I have 2 questions/topics :
  • I can provide you with access to a Eufy siren, are you interested ?
  • I do not understand why : I am not able add a newS340 camera to homey with the Eufy app , the camera does not show in the list of available devices , it shows another existing S340 camera from a second site, that I do not want to import at this stage on this site
    • i have other ones that are OK
    • The full site is shared with my homey account, so it should be able to see all cameras (it is seeing the other ones)
    • Any ideas how I could see this new camera or what i could be doing wrong ?
Best regards,
Paul
Hi Martijn, I tried again and here is the errorlog
9aa88301-7b23-4d0e-806b-776ea4ee3ba6
User and pwd are correct. It doesnt let me add the wired doorbell
Okay thank you. Then i think i don’t use this app. Because your example still gives a notification when Isabelle triggers the camera (the notification comes from ‘is not exactly michael card’ ).
In my case i would like to have a flowcard with ‘@person is not exactly Michael AND Isabelle’, then i need to recieve a notification or a card with ‘person is unknown’
@M_J if you use this app is up to you.
But if you want to fix that use the ALL block :wink:
Hi @PaulS
  • I already have access to a siren but not really able to add it due to reverse engineering
  • Please share a diagnose report, and I think site is app? Or do you mean something else
@Paul_Kessels did you read my question ?
I asked which doorbell you had…
Edit: the report you send me is the same one as yesterday. Please read my answer on that [APP][Pro] Eufy Security - #7655 by martijnpoppen
Yes exactly, but that’s the thing. If i test it, it won’t work with the all, only with the any :wink:
And don’t get me wrong, i’m glad there are people like you, who making these apps. Otherwise homey is almost useless :wink:
