[APP][Pro] Eufy Security
Hello martijnpoppen,
I tested it with Pan&Tilt and it doesn’t help :frowning:
Maybe problem is that at new software this cameras are added to HB3 and doen’t use it own Wifi directly.
I don’t know. But after update problem isn’t solved :frowning:
Thx for tying
@Lukasz_Kostek I used my other pan and tilt with this firmware and works perfect
Exactly same setup as you
Maybe I try to reinstall them
are You using connectin directly to HB3 or with Wifi? In new softwere there is a choise
@Lukasz_Kostek I tested both
I readded it to HB3 once again but the problem remains :frowning:
I don’t know why.
I’m really thankfull for Your help.
Best regards
@Lukasz_Kostek please send a report
Cheers for your prompt reply as always! Would love a how-to.
@Lukasz_Kostek
Finding from my side.
So I encountered the same.
After my fix the lens of the camera turned on/off. And also the camera showed it was off or on. However when i wanted to play live video i got the message that it was not possible to stream. I re-added my camera and now it works. :sweat_smile:
Will check what i can do, but what issue do you have, the on/off or the stream? or both?
I have both. Lends og the camera doesn’t turn on/off.
When I have camera turned On in Homey live video doesn’t work. When camera is turned Off in Homey live video is working ok.
I don’t know why my lens doesn’t hide.
I re-added it and that doesn’t help :frowning:
@Lukasz_Kostek can you send a diagnostic report?
I sended via homey web app
Just to give an update, managed to get the docker container working through Koyeb. Once again, thanks!
One thought/feature request in relation to this: would it be possible to add a when-card with a trigger for when a snapshot was refreshed? This way I could be 100% sure that it is not an old snapshot I recieve/send for AI analysis.
@Zakarias_Mortensen hmm that might be possible yes :thinking:
@Lukasz_Kostek thanks! And you have your camera connected to the HB3 and Wi-Fi or to the Wi-Fi of the hb3?
This is really new functionality from Eufy. Hope that I can fix it.
I chose HB3 as my connection when I was re-adding cameras…not the WIFI. I think camera is using HB3 Wifi.
@Lukasz_Kostek can you try changing it to Wi-Fi? Inside the Wi-Fi connection option select your own Wi-Fi
I changed to my wifi in settings of my camera but this didn’t help :frowning:
@Lukasz_Kostek meh ok
I’ll dive into it a bit more in the coming days
Will come back to you
Hi Martijn
5b34c7e5-9b82-49fa-abe0-143a399ab832
Thanks
