[APP][Pro] Eufy Security
0ff411b7-08da-4b44-8bb8-b646a7a919f1
When I shut down my electricity at my home and after I open it again. The eufy app dont re-login automatically and im doing it manually
@iGiorgis still the same question… what does the device say when it has a red triangle
I dont remember any message, but only the red triangle to all Eufy devices.
When it will happened again I will tell you.
@iGiorgis nothing to see in the logs that looks like that the notifications are not working
Are your settings the same as FAQ Q1?
of course. I receive notifications
@iGiorgis strange.
Can you try a different flow?
If person detected - send notification
And see if that works
To rule out the variables you set
this flow works
@iGiorgis then i think it has to do with the variables you made in the flow earlier
I would suggest to remove them as they don’t seem to add value (in the flow you shared)
Ok I will remove them…but when I click the “play” button from Person Detected AND Button Pressed, the value of them goes to YES.
I understand however the other flow works so we can rule out it’s an app issue. So there’s not much I can do here
Ok then I will wait the new update. thanks a lot.
I test this now… I create 2 simple flows
The values have the YES now BUT…
Dont run this flow automatically
Only If I click manually the “play” button of the first Logic works!
@iGiorgis still doesn’t look like a app issue to me
Also wondering why you want to use the variables it feels a bit overkill for this purpose
because I would like to make a flows:
If Person detected AND Press the Button , Open The light.
If Not detect a person , close the light.
this simple job :wink:
@martijnpoppen the Eufy app dont have enough cards at “AND” section to compine jobs together, so I use Logic to make it.
Do you suggest something different?
@iGiorgis you can check with the logic cards but I would suggest to use the values from the doorbell
So like this:
I use the values from the doorbell but works only once…
Anyway I will remove the “Person detected”. I will keep only the press of the button to open the light of the Entrance.
Thanks
@iGiorgis I have to say that I almost never had a silmutanious detection (ring and person detection) most of the time there’s some time in between causing these kind of flows to fail more often than succeed.
Maybe I can take a look in creating this combination on the app side.
Atleast you triggered me to add some AND cards to the app :wink:
Hi Martijn,
Were you already able to upload the update? I don’t see any new card, or option to enter a specific known person, or do I need to update something first?
THX,
Erwin
@Erwin_Snijder which update ?
