@martijnpoppen, Thanks a lot for your efforts for this Eufy App. Works perfectly!
Regarding the self-hosted snapshot docker image. I have an older type of Raspberry Pi I would use to run this service, however getting the error:
latest: Pulling from martijnpoppen/com-eufylife-security-snapshot
docker: no matching manifest for linux/arm/v6 in the manifest list entries.
Any chance to make this image available for this version of arm processor?
@martijnpoppen i have addes a custom mode in eufy (slapen). In homey the name is still custom 1. When i enable it you can see the slapen mode in eufy itself is activated. But you cant make any flows work with this. For example you dont get the notification in eufy itself that the mode slapen is activated when it is done with a flow from homey. Or when you make a flow when mode has changed and mode is custom 1 send message for example. then it doesnt do anything when you active custom 1 mode. Not sure if i make any sense.
I just the E340 dual doorbell, got it homey and trying to set up some flows, there seams to be a couple options missing, or i can’t work out how.
how do i get a persons name tag when they press the doorbell,
is there an option for packages.
can you help me set this up
thank you.
