Gonna try the test version, will report back when my son has cried haha (probably tomorrow)
New app update (
LIVE: 3.23.2):
Changelog:
NEW:
1: NEW: Indoor cam S350
2: NEW: Enhance Minibase chime support T8023
3. NEW: Floodlight Cam E340
4: NEW: SoloCam C210
5: NEW: enhanced login page
6: NEW: enhanced captcha pageFIXES:
1: FIX: battery life
2: FIX: discovery of S350
3: FIX: E330 remove battery
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Click on the link above Martijn shared and select Install.
I can confirm that both motion and cry detection are working again ![]()
@Jeroen_W Nice! there were some fixes in the latest version for that ![]()
@martijnpoppen , just a update on the battery consumption for the 1080P/2K battery doorbell that was about 6% earlier, now it is a little bit decreased. Over the 3 last days, it is 5.33%. The app has updated so many times since the initial “battery fix” release, but i assume the “battery fix” is unchanged in the different test versions.
Regards
Marius
@Marius_Stensrod correct those were other fixes and additions ![]()
Finally!
eufy Security Siren (105 dB Wireless Alarm)
What do you say @martijnpoppen - do you need access to the actual product in order to implement support for it?
@Peter_Kalrsson ehm i dont have the tools to debug it.
So i have to wait on the library to update.
But you can put it on a issue there as a request to speed it up. GitHub - bropat/eufy-security-client: This shared library allows to control Eufy security devices by connecting to the Eufy cloud servers and local/remote stations over p2p.
Thanks! ![]()
@martijnpoppen I wonder if it’s possible - I do have 3 homey:app:com.eufylife.security:driver_INDOOR_CAM_PAN_TILT and can’t control one of them - on/off (no error just not having any effect on cam - same model, same firmware… ), anything else seems to be working (detections, picture etc.). I even tried to remove it. Original app works. Is that even possible ? It’s the one with ID 739a094e-ed67-4c58-8dfe-f58f8684638c - I sent debug 5f2c7e90-375f-414a-8a91-cb3b722bfa61 but doubt its anything you can influence, if it works for two… ?
Thank you.
@Sharkys looks like the local connection cant be made. You can override the ip of the camera in the device settings
Goede dag
Mijn homey loopt iederekeer vast/ offline wel op internet maar niet toegankelijk. Kwam er achter als ik met eufi app bezig was liep hij weer vast deze nu uitgeschakeld en het probleem lijkt nu weg te zijn kunt u helpen ge gerrit
Good day
My homey freezes every time / offline, on the internet, but not accessible. I found out when I was working with the eufi app it got stuck again, it has now been disabled and the problem now seems to be gone, can you help. Gerrit
@Gerrit_De_Vrij unfortunately i cant
The Eufy app is quite heavy in memory but unfortunately theres nothing left to reduce that
Probably your Homey is running high on Memory and then it gets stuck. Only advice i have is to check if you can reduce your apps on your Homey if you want to use Eufy
Unfortunately this is what it is
@Gerrit_De_Vrij please remove your post in Dutch
Hi @martijnpoppen , any idea why I get a common.x error message when I try to send the status of a sensor to myself over push notification?
Thanks.
Not sure. Thats a Homey capability. Any Steps to reproduce this?
Anyone Else experience problems regarding stability?
The app freezes and quit updating pictures and motion detections.
Also the flow where I put the armed state to away during the night stops working
I have version 3.23.4
