[APP][Pro] Eufy Security
@Heula
Yes the Motion sensor i’m working on. The motion/door sensor Will work like Every other motion/door sensor.
So you can use Them in flows.
Do you also own the door sensor? If so can you test it in the test version of the app. (When your homey is back) :slight_smile:
Good to know. :+1:t2:
I own two door sensors and one motion sensor that came with the security 5 pack.
I will certainly test them with new app version when my homey is back.
Thanks.
Hi @martijnpoppen. I tested different flows but couldn’t manage to start a flow using the door sensor. See the pictures for the flows I tried.
Known statuses in the EufySecurity app are ‘closed’ and ‘open’, see the picture. Could there be mismatch between those statuses and the statuses you used (‘Het contactalarm gaat uit / aan’)?
@Hans_Festen i’m listening to the events of Eufy, but might be thats something doesn’t work correct. That’s why I put it in Test first.
For me it might be easier if you enable DEBUG in the settings and send me your ACTOR_ID in a DM. Then I can take a look at the logs.
I enabled DEBUG but I don’t know how to PM you.
I’ll PM you!
FYI:
Doorsensor only works if the notifications are enabled in the Eufy security app.
Without that Homey cannot intercept the notifications.
First thank you for making this app.
I installed it and created this simple flow
https://homey.app/f/KlJ4Qv
But as you can see in the following screenshot it creates 2 lines each time.
But when I look in the Eufy app stoere is just one AAN message.
How can it be fixed that I receive one message in Homey?
Hi @Arnold_vd_Linden ,
I do recognize this problem. Had this a lot during testing.
It means that you registered twice at the notification service.
You can fix it by going to settings - clear all → login again
FYI:
Tested with @Hans_Festen and we can say that the Doorsensor works on the latest test version.
So i’ll release this soon to the live version :ok_hand:
I logged out of the Homey app as mentioned and logged in again. Restarted also the app after a minute.
But I still receives 2 messages in Homey.
Now I also noticed that Eufy is sending me 2 messages when I ring the doorbell. This is something that was not happening before I created the second account.
I also noticed an error in het Homey app when I press the doorbell:
@Arnold_vd_Linden , Hmm that’s weird.
Can you try to make an another extra account (with admin rights) and see if that behaves the same.
And can you enable DEBUG in the Homey-Eufy app-settings and send me your ACTOR_ID in a DM. So i’ll check your logs for the invalid response.
@Arnold_vd_Linden
I found the issue!.
I have the same thing on my indoor cam Pan&Tilt, but not on my doorbell.
It has to do with the notification settings from Eufy icm the Homey app.
Will make a fix for that today.
CC: @RobinS @Jesse_dg (this also fixes it for you)
This is what happening:
IMG_6096
@Arnold_vd_Linden
Yes, Eufy has a mode where they send you text first and the image afterwards. this is called Full Effect Mode.
During development I tried to include all 3 types of notifications, but somehow it doesn’t always work
If you don’t want this for now i would suggest to change the notification settings to Include Thumbnail
As mentioned the fix for the Homey app will come :slight_smile:
Okay.
Great job! :grinning: :+1:
Hi @martijnpoppen,
Just ordered and installed the EUFY doorbell Wired (withoud base but seperate Chime), installation (Homey) was perfect and easy, only had a problem with getting the screenshot from the Eufy, a reboot of Homey fixed that (I think). Thank you for a well maintained app! Can I buy you a beer?
Maybe interesting for some of you, the flows which work great with my old Samsung tablet that I use as a digital Photo Frame and now shows a screenshot of who’s at the door when someone rings:
https://homey.app/f/iFIOUv
for the tablet I use the app Fotoo for the photo frame part and CastReceiver app for adding Chromecast functionality to the tablet. The Fotoo app takes over after the image has been cast due to opening the app when power is restored on the tablet. Works perfect!!
And when I’m watching TV, it will also show up on my chromecast for 30 seconds :slight_smile:
https://homey.app/f/5DzOUv
Hi @Crashy,
Thanks for your message.
Really like your implementation. :ok_hand:
Maybe this is also nice to share with the FB community which have a lot of ideas like this. (Facebook: Homey Gebruikers)
The idea of the old android tablet is really nice. I’m thinking if I can do something like that with my rapsberry pi :stuck_out_tongue:
You said you restarted the app for the images. I have that bug on my list. Somehow after adding a device the image service is not registered correct. Still not sure why this happens.
Ofcourse you can buy me a beer. I have a personal paypal link: https://www.paypal.com/paypalme/martijnpoppen
Thanks a lot for your message! :smiley:
