Nice!
New app update (
TEST: 3.21.7):
Changelog:
NEW:
1: NEW: add MiniBase Chime (T8023)
2: NEW: Add Doorbell E340 (T8214)
3: NEW: Add preparation for Indoor Cam S350 (T8416) (hardware access required)
4: NEW: Add eufyCam E330 Professional (T8600)
5: NEW: Add eufyCam S340 Pan and Tilt (T8170)
6: NEW: Add support for device which can be stand-alone and connected to Homebases
7: NEW: Migrate app to HomeyCompose
8: NEW: add flowcards to new cameras
8: NEW: prepare for Homey CloudFIXES:
1: FIX: Repair not working for some devices
2: FIX: T81A0 - S120 (implement missing types)
3: FIX: Country code for EU
4: FIX: deprecate stream cards
5: FIX: remove persistent data in userdata - fix
6: FIX: energy saving for battery devices
7: FIX: Security mode for Homebase
8: FIX: images not updating
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
Hi @martijnpoppen and all, I guess you knew it already but it’s new for me - did you know that Google Home is capable of showing all Eufy cam live streams , live and on one screen? Even the official app do not have such capabilities… if you knew, pls. ignore
Maybe useful for others.
@Sharkys i knew they were working on it. Nice !
Everything is fine now than before, because at the beginning i got just errors and oroblems but now added S340 solocams and the app doesnt support it. Can y add solocam s340 cameras too to the supported device lists?
@Robert_Szilagyi see a couple post above; [APP][Pro] Eufy Security - #4871 by martijnpoppen
Its not part of the live version yet
Installed the test version so i will try hows perform. I got a bunch of S340 outside so its a good test.
And in English? This the English forum.
Hello Martijn,
Can I ask a question here about Eufy cameras and creating a flow in Homey?
I now have 2 cameras and I receive notifications every time via the Eufy app.
I would like to create a flow in the Homey environment so that when I am not at home or someone is detected between 0:00 and 0:600, I receive a notification. During the day I don’t need to receive notifications if someone is detected, but the event does need to be saved
Thanks
@Niek_Lansink I would suggest to look into the security modes where you can set up when you want to receive data.
PS: can you delete your Dutch comment?
delete my dutch comment.
Where can i receive toy comment and data?
Sorry didn’t get that, what do you mean?
Is this a standard flow in Homey? And should i in the Eufy app ignore/shutt down the notifications?
@Niek_Lansink without notifications Homey can’t react on Eufy: [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum Q1.
But you can set a different security mode and disable notifications in that mode. But keep in mind Homey can’t react to it at that point
I very often lose connection with Eufy account. Homey doesn’t update, shows on old image and is unresponsive when I for instance change the security mode. I have to use repair and log in to account again to fix it. Perhaps this is a problem with Eufy servers?
@Marcus_Bitterling test or live version?
And do you use a separate account for Homey?
Eufy cant be logged in at 2 devices are the same time. For a longer period
I’m on the latest test version and have two accounts. The Homey account is a resident
@Marcus_Bitterling please send a report when you encounter this again then i can check for you
Hi Martijn,
Quick question. Is the S330 (T8423) dual pro video doorbell supported by your app?
Thanks ![]()
Martin
@Martin072 it is. ![]()
