[APP][Pro] Eufy Security
New app update (:orange_square: TEST: 3.20.3):
Changelog:
NEW:
1: NEW: add MiniBase Chime (T8023)
2: NEW: Add Doorbell E340 (T8214)
3: NEW: Add basis for Indoor Cam S350 (T8416) (hardware access required)
4: NEW: Add eufyCam E330 Professional (T8600)
5: NEW: Add eufyCam S340 Pan and Tilt (T8170)
6: NEW: Add support for device which can be stand-alone and connected to Homebases
7: NEW: Migrate app to HomeyCompose
8: NEW: add flowcards to new cameras
FIXES:
1: FIX: Repair not working for some devices
2: FIX: T81A0 - S120 (implement missing types)
3: FIX: Country code for EU
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
Yes, I enabled notifications for a couple of cameras in Home mode, and I can confirm that notifications are working :slight_smile:
will check the other part
Thank you so much!
HI there,
just today while trying to add a new camera Homey lost connection to all devices.
Steps done:
  1. Restart Dufy app
  2. Restart homey
  3. Re-added user per home/location
  4. Re-added user per device
  5. installed above mentioned test version
    Most often, login stalls after entering the credentials (showing “loading” forever), but every once in a while I am asked to enter the captcha before finally nothing happens…
    Any suggestions?
    Regards
    Philip
@naehle yes :point_up:
Diagnostic report:
64dd2536-4564-491d-8bb7-04dc9c92bbb1
@naehle as far as i se the catcha is wrong and thats why it fails
Thanks for your quick replies!
But: Sometimes the captcha shows, sometimes not, but if it shows I enter the correct string (I‘m pretty sure). I‘ll give it a couple more tries… but is there a way around the captcha?
Currently, I‘m already waiting 5 min for it to show up… (after entering the repair mode)
Ishavet a question regarding Eufy and WhatsApp. Are the imagery from eufy cameras stored with a time tag. I have several eufy cameras. I can with the WhatsApp app send a message to homey and say that I would like the last image from all eufy cameras I have around the house. But I would like to only have the last I.e. 8 hours if there is a trigger that atores a image…
All of a sudden, it worked without doing anything different…
Thanks anyhow!
@riiskongen theres no time tag. Its the last motion image
Thanks. I now realise that drinking whiskey and creating flows and asking questions on this forum late at night does something with the spelling and accuracy in different flows;)
Anyway, is it possible to create a time tag “attached” to the images that are stored from the motion events?
Hi, I’ve have invested in some Eufy S330 cameras, but not happy with the detection range, In my back yard I got several Philips hue motion sensors, and I would like them start the Eufu cams.
Can I somehow use a flow with hue sensors to trigger the camera to start recording?
Don’t want to stress you @martijnpoppen :slight_smile: but did you find an explanation why the arm state differs between Eufy app and Homey app? I have a lot of dependencies to the arm state, and I think it’s wrong that is says “Disarmed” right now (since it says “Home” in the Eufy app). Thanks!!
@Peter_Kalrsson no sorry didn’t look into that yet. Sometimes I do have a live next to Homey :rofl:
But will try to check tonight
Did you check the Homebase notification settings to double check?
@riiskongen unfortunately not, that’s not something Homey supports
@Anders_Grasmo Unfortunately not, as this is a reveresed engineered solution we didnt find any way to do that :frowning:
I do agree, that would be THE best option for this app
What? :joy:
I fully understand, off course! Pls let me know if I should test anything. Really appreciate it!
All OK with notifications!
Hi there,
just added a SoloCam S340, and I wanted to check if anybody else got the issue that turning it off/on using homey doesn´t work?
Regards
@naehle yes i fixed that this evening but not yet released
Will do so tomorrow
Great. - thanks so much!
Mobil gesendet
