[APP][Pro] Eufy Security
@martijnpoppen You’re so quick!! Here is the code: 51bde6e6-f735-4a1b-902d-a2cb73d445a9
@Borskietje looks like you restarted the app first before sending a report. Can you trigger a qwuick response and a doorbell press and send a new report after that? Then it will be visible in the logs
@martijnpoppen : Sure! I just triggered the button multiple times. No registered alert in the app. I also manually triggered (by a test flow action) multiple times the quick responses flow. The first times this goes very well. The last two times it doesn’t work any more. Here is the new code: 84264874-9525-49bd-9bc2-a718aa1da874
@Borskietje about the push notifcation for the doorbell press. do you receive them on your phone?
@martijnpoppen Ah, I disabled the notification in the Eufy app. That was the problem.
New app update (LIVE: 3.12.8):
Changelog:
NEW:
FIXES:
1: FIX: arming change without interaction
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Felho @Stjepan_Siljac Fix for the changing modes without interaction :slight_smile:
Should automatically update soon for your :slight_smile:
New app update (TEST: 3.14.0):
Changelog:
NEW:
1: NEW: ADD S220 Solocam
2: NEW: ADD wall light S100 & S120
FIXES:
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@Alexandre_Herault See the above version. You can install via this link and click the green isntall button :slight_smile:
@Giulio_R @vyncke002 @Serg
You alll requested the S100. I added it to the test version of the app. You can install via this link and click the green install button :slight_smile:
It only contains light on/off for now. Will add support for light changing later :wink:
Thanks so much for that info, I may have not got the right doorbell.
Awesome the token is the name as that makes things so much easier. Think it’s decision made then.
Awesome work on the app.
Martijn you are the best. Thank you very much. Now ican set the s100 in schedule mode by geofencing. :heart_eyes:
I followed all the tutorials on page one but it doesn’t work, I can just activate and deactivate my cameras and change the modes.
@JulDozer
@martijnpoppen Is there an expectation when the stream function will be working again?
@Borskietje Unfortunately not. It really depends if we can get it working at all. :confused:
Yes I think now it is good, but battary status not updated correctly.
@Felho yes thats correct see: [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum Q5
Hello
will eufy indoor pan & tilt only react to famous people in homey pro 23 ? would have liked it to work on all people. Incidentally, I don’t have a homebase and then maybe it won’t work at all?
Markus
Hey @Markus_Jonsson
It’s not related to HP23.
To let your indoor cam recognize people you need a Homebase 3
And luck… :wink: In case of my eufyCam 3 it’s really a crap (and yes, I know that some users are happy with it and having great success with AI recognition)
