[APP][Pro] Eufy Security
Hi @Marcel_Kolsteeg
Yes it is send directly to my mail :slight_smile:
Will have a look!
PS: this is the English Eufy topic.
Not sure if it helps, but all detections, even if wrong thansk to Eufy (I see in the timeline human not person tag name), seems to be translated correctly into Homey
Diag to have something to compare to with others debug : ba6e3ccb-c505-4bfb-8af4-990193258339
@Marcel_Kolsteeg Saw your reports. Also see whats happening, will try to figure out why and make a update :slight_smile:
New app update (TEST: 3.11.1):
Changelog:
NEW
1: NEW: library: better image decryption
FIXES:
1: FIX: HB3 Dual Doorbell notification (Person recognition)
2: FIX: memory leak after re-pairing
3: FIX: notification service not started after pairing new devices
4: FIX: door sensor ghost events
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@Marcel_Kolsteeg I think i’ve found the issue. Made an update which you can test. See the instructions in the post above :slight_smile:
@Goliath made a new fix for the dual doorbell. Can you check the latest test version?
Sure, will let you know!
@martijnpoppen Still detecting unknown person. I sent over another report for your review
New app update (TEST: 3.12.0):
Changelog:
NEW
2: NEW: add option for manual IP address for Solocams E/S/L series
FIXES:
@Floppus I added the manual option for the Solocams. Can you check if that fixes the issue for you? :slight_smile:
@Floppus yes i checked, the SoloCams are getting an external IP from the Eufy server. But as Homey and Eufy are in the same network that doesn’t work
I’ll check i i can create a local lookup, but this is fine as a temporary fix
And for us non-dutch speaking? :wink:
@Anders_Gregow oops :see_no_evil:
English, please @Marcel_Kolsteeg
@marcel_kolsteeg
The Eufy API was behind with the data so whenever the API updated the door was already closed.
So removed that check
So far so good (again :wink: )
:crossed_fingers:
Nice @Kuijkens !
Whups, sorry - I just responded via e-mail, had no idea :sweat_smile:
Just tested again, switching modes and on/off still works. So far so good, it’s the first time in months it’s kept working this long so fingers crossed.
Lets hope so ! @Floppus
@Goliath to debug the issue i added some extra logging in the latest release. It will not fix the problem, but next report you send will contain data which will tell us what is wrong :slight_smile:
