[APP][Pro] Eufy Security
Nope that was a mistake! Same outcome though. Weirdly just tried again and this time it came up with a captcha and then then the same error as before whereas previously it never showed me the captcha.
I also tried with 2 other eufy accounts - one my main owner one and another which I’d set up with 2FA for automation purposes and same outcome on both
yes checked it again, but no luck @martijnpoppen hopefully you will fix it :slight_smile:
not sure what is going on but what I observe is the following:
When I log in to the app with the account used by homey, no devices are present.
So I reinvited that account with my admin account and when I login the app it shows all de devices again.
So i’m repairing it in homey but with no luck getting the same error as Jonathan Draper.
I checked again with the account i’m using with homey and logged into the eufy app. I see all the devices are disappeared again.
@martijnpoppen
@Rens_Hoekema they’re not dissapeared, but not showing:
Click the dropdown at the top
Select all devices:
With the 3.6.0 update all devices are working again. No need to log in again.
Thanks Martijn.
@Heula Nice!
Seems like hit and miss at the moment :stuck_out_tongue:
Ok wrong about that but 5f2bcbb1-0d65-4458-84d2-524b037c60f5 still not working
@Rens_Hoekema in case you missed my message :stuck_out_tongue:
I think I did :sweat_smile:
Thanks Martijn, installed 3.6.0 and my Eufy devices are active again. I needed to log in with my credentials after installing the new version :slightly_smiling_face: Thanks for your effort!
new 3.6.0? or another build number?
@michaelhuisman will be a new build number, but not out yet. Once it’s ready it will be posted here
okay, thanks. took a few times, but I actually got the captcha now and managed to connect up 11 devices I need to see.
Nice! :smiley:
yeah, fab work from your side!
Thanks! :smiley:
:warning: Update :warning:
This uses the API decryption methods but might be that your login doesn’t work. Please let me know :slight_smile:
New app update (test: 3.6.2):
Changelog:
NEW:
1: NEW: update library (Decrypt API methods) :warning:
2: NEW: add 2FA support :tada:
3: NEW: enhanced the pairing process (due to 2FA)
4: NEW: Dutch app description
5: NEW: App image updated
6: NEW: changed the fallback image
FIXES:
1: FIX: cloud stream :tada:
2: FIX: App startup process due to recent API changes
3: FIX: event helper errors
4: FIX: wrong email password login
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@Jonathan_Draper @Rens_Hoekema see above :smiley: :point_up:
Error invalid image buffer at this point 6.3.1
Yeah I changed the fallback image :stuck_out_tongue:
But it’s a bit to big. will be fixed in the next one
thumbnails are still broken anyway
