[APP][Pro] Eufy Security
New app update (test: 3.4.10):
Changelog:
FIXES:
1: FIX: remove alarm_motion from Door sensor
2: FIX: show error page for Eufy Stream (Patched by Eufy :frowning: )
3: FIX: remove cover_path Image update (Patched by Eufy :frowning: )
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Thanks for quick reply! :slight_smile:
Then it’s understandable. You’re doing great work. Much appreciated! :muscle:
Hi Martijn,
Hope you can help me with something. I’m trying to sync the security mode between a homebase and a Floodlight 2K Pro with an advanced flow.
Unfortunately it seems like a security mode change of the Homebase doesn’t trigger the flow. If I start it manually in Homey it works fine, but when I change the security mode of the Homebase via Homey it doesn’t seem to trigger, while the security mode changes for sure. (based on the Eufy app) I’ve build in a one sec delay in order to prevent Homey that Homey activates the wrong THAN-card. Also, when I switch modes via the Eufy App, it doesn’t sync with Homey, only the other way around. Any ideas on how to solve this?
Hey @Arjen_Baatje
Make sure the Homebase notifications are enabled:
Hi Martijn, thanks for your quick reply. Settings are exactly as the printscreen you sent.
@Arjen_Baatje did you try to restart the Eufy app in Homey? Sometimes that might fix the issue with the notification service :slight_smile:
@martijnpoppen Yes, that did the job! To bad I didn’t came up with this idea myself. :wink: Thanks again for the quick response!
@Arjen_Baatje yeah it seems like that when adding multiple devices the notification service crashes instead of starting up properly. Will have a look at that soon :slight_smile:
New app update (live: 3.5.2):
Changelog:
NEW:
1: NEW: add notification for Eufy Patch
FIXES:
4: FIX: Show error image for motion images/thumbnails (Patched by Eufy :frowning: )
Hi I give this image motion detected. Can I fix it? 1 week ago it is work perfect.
It is a bug report 14520f8c-34a4-45e4-980d-0b3920933526
Hey @Felho
As the image explains: Eufy patched the API. Nothing I can do at this moment.
You also got a message on your timeline which refers to this forum post: [APP][Pro] Eufy Security - #4 by martijnpoppen
I did put that placeholder image there, otherwise all your Eufy flows will break. :confused:
I see thanks.
Hopefully we can find a fix! Already looking for ways to update it, but no luck yet.
Keeping fingers crossed…I believe that the “patch” is actually related to this issue maybe ?
@Sharkys yes it is. They’re actively patching everything at the moment.
Here i’ll post the latest updates: [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum
Which on the one hand is great, Eufy being proactive about security, but on the other it’s a nuisance
Martijn, do I read it correctly on Github that there is a way to decrypt the new encryption of the images and/or stream? You merged it into a new version? Is it about to be released?
Keep up the good work!!
Hi @martijnpoppen
Is there still an aspiration in this new release to remove the need for notifications? I remember reading this somewhere in the thread but I have forgotten…
Many thanks,
Nick
Hey @FranklyEpic
Yeah it was, but I hit the limits of the API everytime. Eufy locks a user out if the requests are too frequent. Next to that with the latest encryption changes in the API it’s even harder to do this.
So I don’t think it will be possible soon to do something like that
@Roger_Gorissen for the stream : yes
Images: working on it.
Still some work needs to be done, but seems like we could get it working again :crossed_fingers:
