[APP][Pro] Eufy Security
As said before, that’s correct. Not sure what you expect there?
But try the sensor again. because when you sent me the report the app wasn’t finished with starting up. So that will never work :stuck_out_tongue:
op het plaatje wat je eerder stuurde stond als contact alarm gaat aan en het contact alarm gaat uit.
vandaar dat ik dacht dat er 2 kaartjes moesten staan bij als.
maar helaas doet die het nog steeds niet.
krijg wel de push melding poort is open en poort is dicht binnen maar helaas gaan de lichten niet aan
@Daniel_Frankenhuis please keep this thread in english. Or we change to the dutch topic again ([APP][Pro] Eufy Security (nl) - #689 by martijnpoppen)
yeah as said wait a little bit after install, as the app wasn’t started yet
sorry for my impatience.
i will try tommorow morning
You don’'t have to wait that long :stuck_out_tongue:
Should work after like 3 minutes. Then everything is started and connected :slight_smile:
Ik voel mij best wel schuldig
Maar het werkt helaas niet
3e880971-9b8f-4d2e-a8cf-cb03e6e25641
Please keep this thread in english…
I’ll have a look tomorrow why it doesn’t work :slight_smile:
thanks for all the effort you put in. good night
It started working for me last night, but its no longer getting triggered today, also now the rest of my flows arent working or triggering anymore. Hahah, completely baffled
@lukelinsj wow nice :confused:
I do see that everything is working fine.
Is it correct you’re trying to run default response 3?
You might want to restart the app and see if that solves anything :man_shrugging:
Yup that is correct, let me try restarting again
@lukelinsj if you havent done so already. can you make a custom response and see if that works?
I had a similar issue yesterday that only the custom response were working
:man_facepalming: the url Eufy provides for the quick response is not even working…
Seems like they deleted it.
Does it work via the Eufy app on your phone? :thinking:
Tried and tested, both types are not working. It works via the eufy app
@lukelinsj I will do some more tests today!
New app update (test: 3.4.8):
Changelog:
FIXES:
1: FIX: remove alarm_motion from Door sensor
2: FIX: show error page for Eufy Stream (Patched by Eufy :frowning: )
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
FYI @DominicVonk unfortunately the encryption of Eufy is really hard to decrypt. For the time being there will be shown a error page
Quick update, the flows except the doorbell responses are working now, will continue to monitor and update
I just bought two Eufy Solo IndoorCam P24’s in the hopes of using them as a baby monitor on with alerts on my nest hub.
Unfortunately I can’t seem to get my flows to work. I’ve scoured this thread for solutions, but nothings works. Do you know if Eufy has made the URL inaccessible since the whole recent cloud privacy debacle? Or am I simply doing something wrong?
PS. Damn you’re active in this thread. Kudos and thank you for a great app!
Hey @Asbjorn_Fischer ,
Yeah unfortunately Eufy patched their API and it’s broken now. Due to the “privacy concerns”.
I’m working on a decryption mechanism see: [Bug]: Client will be broken soon · Issue #259 · bropat/eufy-security-client · GitHub
Also a update is ready for go live which shows an error page with an explanation for this issue :confused:
