Strange
Can you send a diagnostic report?
You can do that via the mobile Homey app:
More - apps - Eufy Security - settings wheel right top - de diagnostic report
Strange
e728ce28-4b62-4153-ad0b-6ea67a02b439
Done!
@Michel_Helsdingen thanks
Have Somebody else with the same problem. I will dive into it tomorrow!
All good. Tx!
Hi there
I have the same issue.
No device found and looping back to login screen and timing out after 3000
I’m afraid it has to do something with the latest release.
Let you know tomorrow morning
No worries ![]()
Thank you
Hi Martijn,
Can I please give you an error log? My pan/tilt and floodlight cam can be turned on/off in homey but no motion events being registered. 3a9f4d18-3dd1-467f-b0d4-67602aba169c
Its not picking up any motion events for some reason.
Hey @FranklyEpic
I would suggest having a look at the FAQ Q1
probably your push notifications are disabled in the active security mode (home/away/ etc)
Changelog:
1. FIX: pair issue stand alone camera
Thanks for your effort! Much appreciated
Thank you, will give it a try in a few min and send a feedback on it.
I have the latest update now, can see that you pushed it out, restarted the app, putt in my credentials. I don’t get the timeout but I still get or get looped back to the login screen when I try to add a device. In this case it is the floodlight 2 pro.
I have no 2FA on the second accout and I can login via the webbroswer just to confirm it works.
I will try to uninstall and install the app again to see if it solves the issue.
@Revo_Biglarian I can have a look!
I have double checked all the devices and all of the modes, on both accounts and they are all as they should be except I have chosen “full effect” in notification settings.
Nick
Might be multiple things:
if above don’t work:
Absolutely, much appreciated Martin
4325f171-3c58-4da0-9d80-12cbed0fc4ed
@Revo_Biglarian you’re unauthorized. Probably you had too many tries for adding devices and Eufy locked you out for a couple of hours. I would suggest trying again in the afternoon
