For me, none of them seem to work.
Really curious what makes it different from @2Be which at least has sone working
We know that the doorbell supports the functionality; it’s the question/challenge to get them triggered by Homey.
Stop the press… I figured it out, and it’s stupid…
So far I’ve been testing it by pressing on the doorbell button when standing in my door opening, without success.
But now I tested it while standing in front of the doorbell (motion triggered) and pressing it.
I’ll work out the full list and report back the order of the list.
@Wout-1976 updated the test version to 1.8.9 and enabled it for all doorbells
@MrBlue hmm really curious how that works. Can you share a example flow?
The flow is the same as before
If press > Send response x
But apparently, the doorbell doesn’t only require the doorbell to be pressed, but also to see motion first (LED rings starts to light up) before the quick answer will be triggered.
Unfortunately I was only able to test one before my daughter went to bed.
Custom 1 played the message of Default 3 (“We will be right there”)
@MrBlue ah that does make sense. I started the counting of the messages at 0.
So will change that to starting index 1.
Hi! New user since one day here
Will the motion sensor (https://www.amazon.nl/dp/B083KHPB8R/ref=cm_sw_r_cp_api_i_7FCeGbMK5QEHF) also be supported? Thanks!
Now snapshot does not work.
I see the picture of all the Eufy products.
@Wout-1976 That happens after restarting or updating the app.
Once you trigger the doorbell again and it includes a snapshot in the notification, it should appear in Homey as well
If you just rebooted yes. Because the previous image is unkown. Any motion or doorbell press will trigger a new snapshot
------------EDIT---------
yes What @MrBlue says
Hey @Bas_R
Got this question yesterday too. For now i’m not sure if it’s going to work. Every Eufy product works differently. As I don’t own the motion sensor it’s a bit of a guessing game. But will research and give it some tries.
Yes it works again.
But is it possible to use the RTSP stream?
Can’t find settings for that in de original Eufy app.
Checked together with @MrBlue .
But we couldn’t find any option for it.
Now it seems like somebody manage to do it.
So will give that a try. But Homey will not consume this RTSP. So only if you want to enable it it might be possible.
And perhaps i can send the stream to my Synology NAS.
I’ll put it on the list then
haha
Great! Also, if you have a battery powered doorbell yourself, you might consider buying it because of this. Link a motion sensor to your doorbell to enhance the battery life | Security Made Simple - Tips & Tricks - Eufy Security Collective
I’ve bought it for 20 euros during Black Friday, so it’s not expensive.
Yep would be nice. But I don’t own a doorbell myself. It’s on my what-to-buy-for-my-smart-home list
Is that any way to integrate the Door/windows sensor?
