Hi Sven, My Duux Bora with serial number 24… works with the Duux app (gen 2), but somehow I can’t get it connected in Homey. Either it doesn’t see new devices, and sometimes when it looks like homey comes across something, it says “Cannot read properties of null (reading ‘length’). Any idea?
Hi, great app, nice to have some homey control again with gen2 devices ![]()
Is it possible to also add the Whisper Flex Ultimate? I can see the Flex, but the ultimate does not show up, but uses the same app (gen2) and account .
If possible that would be great
I was wondering… Are Duux Edge Oil Radiators also supported?
Not yet, but I can definitely add support if you send me the config (More→Settings→DuuxGen2 in the Homey mobile app)
I am thinking of buying one or more of these radiators, now I am stuck with a couple of Mill Oil Heaters which give me a lot of trouble…. Constantly disconnecting from Wifi which is giving me headaches, and I am not the only one…. Mill does not do anything to fix these problems….
I have a Duux Bora and while I had some issues during the setup (which was solved by re-installing the mobile app), it works very stable both in Homey and the Duux mobile app.
I can definitely recommend Duux products!
I just bought Me a Duux Oil heater, so If you want to support this device I can send you the config. But am not quitte sure how… In the App I can go the device and from there when I go to More => Need Help on this device I get a popup screen with additional information like Code Name, device ID, Product ID, Firmware Version, Space ID and so on. Is this what you mean?
Hi, with the latest version for my whisper ultimate the slider shows 0,01 til 0.3 but that stops the fan.
This scale is not working as the max level still stops the fan from turning.
The issue should be fixed, but I don’t know what you mean with the 0.01 to 0.3. Do you see that in the device screen or the Flow card?
With 2.1.7. still the same behavior. Slider values are to low, and fan won’t start with low or high value.
